I have an F122 from Sept85 that developed random keypresses being registered after a few months of continuous use. At first I thought that the foam was very likely in need of replacement. I used a neoprene sheet and did that, but my issue persists. I have done more investigating it the issue appears very strangely.
If I plug in the kb, at first it behaves pretty nicely. After some time, striking the keys with a decent force will register keypresses everywhere. Keys at opposite ends will register. At its worst, if I let the space rise too quickly, the keyboard will go bonkers, hold some keys down, type many all at once, lock my PC...
The issue is much worse and easy to make happen if the case is put on. If I tighten the case fully, the keyboard will almost be totally unusable pressing keys everywhere.
Pls Help
