Filco Majestouch Ninja gives a slightly springy sound on enter key
tmpdev101
30 Jun 2017, 05:46
I just purchased a Filco Majestouch Ninja. Its all ok except for the Enter key. Upon pressing the Enter key it gives a slight springy hollow sound. Is this normal behavior?
-[°_°]-
30 Jun 2017, 11:11
unfortunately, yes, it is a very common issue with filco.
what switches do you have?
