Mac OS X mistakes keyboard for XT?
- Chyros
Hey guys, when I was using my ZKB-2 with an AT adapter and PS/2 converter it worked fairly fine, but now that I'm using an AT/XT Soarer's converter for it (I need the PS/2 one to test things with) for some reason the nav and numpad output only numbers, a bit like it were as if it was stuck in XT mode. No, the keyboard is not set to XT mode. Unfortunately, I can't find a way to toggle Num Lock, which might have resolved the issue, and shift+nav or +numpad doesn't return arrow functions either. Does anyone have an idea of what might be going on here and how to fix it? Cheers!
- Zed
- Main keyboard: Unicomp Model M
- Main mouse: Ducky Secret
Hi Chyros. So, Num Lock would toggle with the AT/PS2 converter setup and now does not with the Soarer's converter? Is there anyway you can see the scan codes the board is sending? Perhaps the Soarer's setup is sending a 'CLEAR' rather than a 'NUMLOCKCLEAR' code? (OS X replaces Num Lock with Clear and maybe Soarer is doing the same)
There may be some more help in this article (ie. pressing Alt/Option 5x?):
http://osxdaily.com/2014/12/01/number-k ... board-fix/
- enrique.aliaga
- Main keyboard: Constantly switching
- Favorite switch: Topre 55g
Isn't macOS incapable of Num Lock? Alternate navigation functionality doesn't work on number pads, under macOS.
- Chyros
Maybe it's not that, I don't know. But it does seem to be a numpad-related issue, as the arrows output numbers instead.
I've tried pressing Alt 5x, that didn't appear to do anything unfortunately D: .
- DT Pro Member: 0190
My ZKB-2 does that too actually. I think the fix is just to remap those keys to numberpad keys and check that the scan codes coming off of them aren't funky using HID_listen. Haven't actually gotten around to trying it myself, but I see no reason why it wouldn't work.
