4 different 60% keyboards made by MonkeyKing Custom
ingeniousmonkey
14 Aug 2017, 04:58
Features:
1.Multiple programmable layers
2.DIY interesting & useful RGB backlit, fully user-defined
3.Hot swappable switches for MX-based or optical mechanical switches
4.Innovative visual smart driver software,easy-to-use
For the attached 4 models,MonkeyKing Custom can supply pre-assembled items, custom kits, and DIY PCB parts. Are you interested in the group buys for them? :)
GBstarts.
ingeniousmonkey
25 Aug 2017, 11:53
update!
Group buy will start in next week.
ingeniousmonkey
04 Sep 2017, 04:12
Update:
GB will begin on September 5.
TuxKey
LLAP
04 Sep 2017, 17:37
If you ever decide to make a layout like this one.
Count me in ..make it programable and chip direct from china (modifying the customs price) and i'm in all the way..
BTW; havent found a manufacturer that made this layout only a fellow DT keyboard lover that made it himself.
100% standard keycap compatible and yet compact. with arrow cluster
ingeniousmonkey
08 Sep 2017, 09:13
Update
