[IC] Optical Switch (Light Strike)60% mechanical keyboards, DIY kits
ingeniousmonkey
26 Aug 2017, 17:17
Hot swappalbe optical switches;
Waterproof & dustproof completely, with nanometer technology;
Full RGB backlit, fully user-defined;
Smart software programming for multiple programmable layers;
Technology bring users benefits. Best cheap 60% keyboard 2017.
61-key poker layout and 62-key with dedicated arrow keys layout are available.
The group buy will come in next week. Multiple buy choices: the pre-assembled finished products, custom kits, DIY PCB can be chosen
Are you interested in them?
61-key optical keyboard with poker layout http://www.pc-100.com/portfolio/61-key- ... er-layout/
62-key keyboard with dedicated arrow keys product details http://www.pc-100.com/portfolio/62-key- ... t-keycaps/
Optical Switches introductions http://www.pc-100.com/photoelectric-swi ... rd-switch/
More introductions:
1. (Light Strike) Optical switches are with high reaction speed and durable than MX-based switches', especially for gaming. Hope it can be an excellent gaming keyboard. Of Course, office or programming use will be no any problem, it is also very good( different kinds of optical switches can be chosen, such as brown switch, blue switch, red switch, black switch...)
2.Optical Switches are used in 60% keyboard for the first time by us. It is an innovation design in mechanical keyboards industry. We hope to hear some advice from community users.
3. About PCB board's warterproof, we adopted nanometer waterproof technology, it can let the whole board be water-repellent completely, washable, even can reach IP68 level. In cybercafe, office, home, even adverse working conditions, you will never be afraid of any water, coffee...
60% hotswap switches keyboard, RGB programmable
60% keyboards.jpg (223.14 KiB) Viewed 2696 times
GBstarts.
[ XMIT ]
26 Aug 2017, 18:15
How reliable are the LEDs used in the optical sensors, and what happens when they fail? How many hours will they last?
ingeniousmonkey
27 Aug 2017, 04:59
XMIT wrote: How reliable are the LEDs used in the optical sensors, and what happens when they fail? How many hours will they last?
The infrared couples are SMD soldered on PCB to guarantee their electrical performance, these infrared couples are specially customized for our mechanical keyboard by EVERLIGHT( a key player in the global LED industry). Many strict experiments and testing were passed before we apply them into our mechanical optical keyboard. The infrared couple's projected lifetime is far more than 30000 hours with stability.
ingeniousmonkey
04 Sep 2017, 04:14
Update:
Group Buy will start on September 5.
ingeniousmonkey
08 Sep 2017, 09:20
Update:
GBstarts.
