[New]Kailh Mini Choc Switch PG1232
kailh
12 Sep 2017, 04:18
Pretravel:1.2mm±0.5mm
Actuator travel:2.4±0.5mm
more info http://www.kailh.com
DarKou
12 Sep 2017, 11:12
White shaft and Brown shaft do interest me!
Is it possible to buy some of them (3 or 4)?
ideus
12 Sep 2017, 19:15
There is no information about this model in the site switches' catalog.
n0rvig
12 Sep 2017, 20:42
Is this compatible with other switch caps?
InvidiousIgnoramus
13 Sep 2017, 21:27
Wait, are these different from the other low profile switches that kailh released? They sound a lot like those ones, but with a different color stem.
13 Sep 2017, 23:09
Seems so, as those were [wiki]Kailh PG1350 series[/wiki].
Kurplop
14 Sep 2017, 02:59
Smaller switch, shorter travel. 1.2mm pretravel vs. 1.5mm for 1350. 2.4mm total travel vs. 3.0 for 1350.
I wonder if they work as well as the 1350?
kailh
14 Sep 2017, 05:36
DarKou wrote: White shaft and Brown shaft do interest me!
hello.it isn't the PG1350
kailh
14 Sep 2017, 05:36
Kurplop wrote: Smaller switch, shorter travel. 1.2mm pretravel vs. 1.5mm for 1350. 2.4mm total travel vs. 3.0 for 1350.
yeah,
kailh
14 Sep 2017, 05:37
ideus wrote: There is no information about this model in the site switches' catalog.
it's our new low profile switch
the site haven' t been updated
kailh
14 Sep 2017, 05:39
n0rvig wrote: Is this compatible with other switch caps?
hello,it isn't compatible with MX keycap,please find the picture
kailh
14 Sep 2017, 05:41
InvidiousIgnoramus wrote: Wait, are these different from the other low profile switches that kailh released? They sound a lot like those ones, but with a different color stem.
only smaller than PG1350
kailh
14 Sep 2017, 05:42
Daniel Beardsmore wrote: Seems so, as those were [wiki]Kailh PG1350 series[/wiki].
nope,it's PG1232 just size smaller than PG1350 series
14 Sep 2017, 09:20
Don't make me go Clouseau on you …
Draghmar
03 Jul 2018, 14:57
Does this keyboard use those switches?
Motospeed CK94
It looks like that from the pictures but I can't find any confirmation...There more pictures at two china stores if you want to look for it.
kailh
04 Jul 2018, 08:19
Draghmar wrote: Does this keyboard use those switches?
Motospeed CK94
not,Motospeed CK94 is Choc Switch PG1350
Draghmar
04 Jul 2018, 12:26
kailh wrote: not,Motospeed CK94 is Choc Switch PG1350
Oh, ok - thanks! So it's clicky then. And here I thought I finally found keyboard I'm looking for. ;)
spex
01 Oct 2018, 13:41
No, that's not a given. It could be clicky, tactile, or linear. Since it's a gaming keyboard, it's likely linear.
wiki/Kailh_PG1350_series
