However it is seriously impossible to search for the name of the part I need. The assault in question consisted of a fist being brought down on the ball with excessive force. One of the little plastic (teflon??) "beads" that the trackball sits on has completely disappeared. It was either crushed or popped out and will Definitely Not Be Found at this point.
I need the thing circled in yellow. My trackball has simply the plastic surrounding the "bead" remaining, it seems like to me that if I had another "bead" I could easily glue it in there.
It's not a "bearing" because it doesn't rotate, its not "plastic" necessarily because the ball glides on it easily... I dunno what it's called!
I'm not even sure that you can replace this little guy. But I have to know for sure. If anyone has any idea how I can fix my poor trackball please let me know! Help me make my trackball Battle Tested instead of a Casualty!
