white vs blue label model m. Is the difference just the date?
- wobbled
- Favorite switch: Topre
- DT Pro Member: 0192
Thickness of steel plates changes (the earlier, the thicker) thickness of cases (also earlier the thicker) you will also find that some late lexmark models use flat fixed cables as opposed to SDL removable cables.
The feel of the switches stays essentially the same.
- Ir0n
- Main keyboard: IBM Model F107 / SSK
- Main mouse: logitech lift
They also sound different in my experience which I guess it's due to the thicker plates on the older ones
You can't go wrong either way they are all great boards
- seebart
- Offtopicthority Instigator
- Main keyboard: Rotation
- DT Pro Member: 0061
