First time keyboard design tips
AuthenticDanger
- Main keyboard: Kona Classic
- Favorite switch: Cherry Tactile Grey
Learn how to model using something like Fusion360 or AutoCAD and learn how to route PCBs in something like KiCAD. There are tons of resources for both, just not specific to keyboards (though there are some good keyboard PCB design resources).
Google will be your friend.
AuthenticDanger
That's not always true. You can get PCBs made for really cheap if they aren't massive. Sometimes it makes sense to use a PCB even if you're not going to sell or "mass" produce 'em (look at the Mitosis, for example).
__red__
- Main keyboard: 4704
- DT Pro Member: 0186
Sure, but the OP is talking about building a 3D keyboard and flexible circuits are not only insanely expensive but modeling the correct distances across a curved surface is hard.
