Mechanical Keyboard help
crven123
20 Jan 2018, 20:24
Guys what do you think about this keyboard? https://ms-start.com/en/ms-thunder-pro- ... small.aspx
should i order it,its only 40 USD?
And what switches does it have i think they are blue
Dingster
20 Jan 2018, 20:29
Nije slaba :D
For 40usd its a good deal imo, at least for a first mech. Switches are deff "outmu" blues as it says on the box (probably OUTEMU but miss spelt). Found this review too https://www.youtube.com/watch?v=vKBKYLN_E8o
If they are outemu blues they are pretty solid.
rich1051414
20 Jan 2018, 21:19
Outemu's are really crisp switches. They may not be as reliable as other brands, but they aren't bad, especially if they are the 'boxed' outemu's. They sound wonderful and have low stem wobble and better dust resistance.
AFAIK, the boxed variety only comes in keyboards that advertise that the switches are hot swappable though, so I doubt they have the good ones. The boxed variety comes with hot swap sleeves installed, so it would be something they would advertise.
Comparison:
30pcs-OUTEMU-RGB-SMD-Switches-Dustproof-Black-Red-Brown-Blue-RGB-Swithes-For-Backlight-Mechanical-Gaming.jpg_640x640.jpg
30pcs-OUTEMU-RGB-SMD-Switches-Dustproof-Black-Red-Brown-Blue-RGB-Swithes-For-Backlight-Mechanical-Gaming.jpg_640x640.jpg (149.55 KiB) Viewed 1491 times
My only reservation would be the controller itself. I had one experience with non-boxed outemu's with seriously bad chattering issues, but that was due to the controller in the keyboard not playing nice with the switches. It isn't inherent to the switches.
crven123
21 Jan 2018, 03:56
Here are the switches http://prntscr.com/i3cfbe what switches are they and are they any good?
rich1051414
21 Jan 2018, 08:52
Those are the boxed version. I like those :) Interesting, I wonder if you can get them in keyboards that are non-hotswappable now.
