Found this trackball on Aliexpress, thought you guys might like it. There are other similar ones. This is the cheapest one I found that has a 35mm ball. There is a 25 mm one at the same price.
https://www.aliexpress.com/item/Panel-m ... autifyAB=0
Panel mount USB Metal Trackball from Aliexpress
green-squid
- Main keyboard: --
- Main mouse: --
- Favorite switch: --
- HTB1aO3OMpXXXXajXVXXq6xXFXXXH.jpg (343.3 KiB) Viewed 2637 times
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
My suspicion is that the buttons would be fairly stiff. Not just that, but the obvious place for the primary button is below, under your thumb, so why are the buttons way out of reach? Also, since the ball is shiny, does that suggest that it's optomechanical?
