Retr0bright - German options
EspritBerlin
13 Feb 2018, 22:36
Dear All,
since I collected Cherry keyboards in the late 90s, I stored some in a box in my cellar. A few weeks ago I found a Cherry G80-1000 HAD, manufactured B02 (in 1989) - made in West Germany. It has 3 modes PC/XT, AT02, and MF and should work via DIN to PS/2 connector today.
It was not in bad shape, but the ABS was very yellowed since the time I picked up the keyboard (somewhat around 1998).
G80-1000 HAD (1989) - yellowed ABS
G80-1000 HAD, type platze
I read a lot about Retr0bright'ing the ABS, but most of the formulas are UK or US based.
So: what to buy in Germany? I looked for a German and easy option and went to a local shop for hairdressing supplies and bought "Cosmo, Profi-Hair" (Oxy creme 12%) and blonding powder I mixed the creme and the powder about 1:1/3 and followed the regular Retr0bright procedure: apply to ABS, wrap in plastic wrap to prevent drying out (and keep the mess a little bit less messy) and exposed to the sun almost the whole day - in early February :-).
Bleaching the ABS
Bleaching the ABS
The weather that day in February 2018 was sunny, but cold, around 5 degrees Celsius (41°F).
The case was nasty
Case and oxy creme/ powder
and I did not expect a good result using my untested mixture.
But ...
Almost new G80-1000 HAD
Detail
Detail
I was very much surprised and happy.
After cleaning off the bleaching residue I tested the keyboard. All keys work, also the LEDs.
Happy Retr0bright'ing, best regards from Berlin
EspritBerlin
OldIsNew
13 Feb 2018, 22:44
Nice, looks good! I'm impressed with how the case came out (and the keys). I have a couple of cases I've been thinking of doing, but have been afraid of getting blotchy results - I may have to go ahead and try one now.
Wodan
ISO Advocate
13 Feb 2018, 22:47
Not really hard to come by in Germany:
https://www.amazon.de/SM-55-Wasserstoff ... ref=sr_1_7
ShivaYash
13 Feb 2018, 23:02
Nice!
wickedbrain
13 Feb 2018, 23:08
Awesome job brightening that old lady up again! :D
Sangdrax
14 Feb 2018, 05:20
That turned out just fantastic. Great job!
Cattus_D
14 Feb 2018, 10:28
Looks good! Thank you for sharing.
PlastikSchnittstelle
15 Feb 2018, 15:50
WOW, great job you did! I got some of those from ebay just to get the caps. Never seen one of these boards in such a clean and shiny condition before. Suddenly I'm so much wore attracted by it.
I would say you made this keyboard travel back in time :D
kohlerm
19 Mar 2018, 08:37
Thanks! Good to know what to use for brighting in Germany.
I wonder whether those keycaps were really white originally, or whether they are beige.
I have some from en MY cherry board which look very similar, and I wonder whether it should try to bright them
Iggy
19 Mar 2018, 09:17
Wodan wrote: Not really hard to come by in Germany:
Thanks for the link. So that is the only liquid one needs to Retr0bright?
twinrotor
19 Mar 2018, 15:34
Looks like you might have got up to 14% or a little higher with the mixture you used. I don't know if 2% in solution is going to make that much of a difference.
I've also seen successful attempts with less than 14%, as distilled water is added to cover parts (liquid), rather than a creme.
