Hi there,
I just bought my first mechanical keyboard: Corsair K63 (The one without num-pad). It has Cherry MX Red switches. Everyone recommended me these for gaming, but now that I have it I get fatigued by using it playing shooters which require u to hold buttons down, such as Shift+W. Holding it down causes strains and I can't play for too long. I've checked all the switches, and I was thinking 'bout changing this K63 for a keyboard with brown or blue switches. IMO the blues sounds the best option for me, because they click, and holding the button down won't cause any strain or don't require alot of power. Am I right on this? Please help me finding the perfect switch.
P.S. I only play shooters
Greetings!
Muzky
Need help choosing the right switches
- Dingster
- Main keyboard: Novatouch
- Main mouse: MX518
Yes you should be fine with blues, they require only slightly more actuation force. But remember when you press the blue switch down you will feel a "bump" and hear a click unlike just sliding down like with the reds.
- Main keyboard: Whitefox Zealios 67g
- Main mouse: Logitech G900
- Favorite switch: Alps Orange
Your problem is you are holding the button down further than you need to. You don't have to hold the switch bottomed out on mechanical keyboards. That will just fatigue you.Muzky wrote: Hi there,
Greetings!
Muzky
You should use a tactile or clicky switch to teach yourself how far you need to press the switch. Linear switches give you no feedback on how far is far enough. I do not recommend browns for this purpose, the tactility is too subtle.
I have a serious case of Deja vu right now.
- Daniel Beardsmore
- Main mouse: MS IMO 1.1
I'm confused about how holding MX Red can cause strain, as they don't require much force to press or hold.
What keyboard did you have before this? Surely full travel force on that keyboard was no more than it is for MX Red!
