IBM part numbers
Myoth
03 Mar 2018, 12:04
While I was watching what happened to the wiki recently I saw what Daniel and tactica had made to the [wiki]IBM_part_numbers[/wiki] and I think that since this is such a huge topic it needed it's own thread.
I have a few questions first :
-how did you find the 1386853 and such obscure layouts ? did you just assume their part number by looking at the part number scheme of other keyboards ?
-do you guys plan to add the Japanese section of IBM ? the JX, Multistation and such. I can help you with that if you want ?
Myoth
03 Mar 2018, 12:15
added the 6111082, 2683215 and 1386965.
Myoth
03 Mar 2018, 20:47
  1. It would be nice to know who does this belong to, as I don't think we have a SSK with the french layout in the pn list other than the Indies.
    https://www.flickr.com/photos/mr_mayhem/7406647092/
  2. There is also this thing here with a lot of mistery around it :
    wiki/IBM_Model_F#IBM_4980_Keyboard
    I wonder badly what's its part number. You guys might know ?
tactica
04 Mar 2018, 02:51
Myoth wrote: -how did you find the 1386853 and such obscure layouts ? did you just assume their part number by looking at the part number scheme of other keyboards ?
No assumption, that one and many others were found by checking official documentation from IBM. Take a look at the references. Documentation with lists of P/Ns are precious, a (complete) list of 4704 keyboards for example would be virtually impossible without that.
If you are going to contribute to this page, please use references in your entries whenever possible. That alone won't make the information correct, but it allows the reader to know that it isn't made up at least.
Also, a proper change log in your edits wouldn't hurt. This is best practices for every wiki editor anyway.
Please be my guest :D
Lexmark branded keyboards do not belong into a list of IBM P/Ns however. That should go somewhere else.
Myoth
04 Mar 2018, 20:25
tactica wrote: No assumption, that one and many others were found by checking official documentation from IBM. Take a look at the references. Documentation with lists of P/Ns are precious, a (complete) list of 4704 keyboards for example would be virtually impossible without that.
yeah I figured after I posted, I search more in the references and eventually found some lists of pns you used.
tactica wrote: If you are going to contribute to this page, please use references in your entries whenever possible. That alone won't make the information correct, but it allows the reader to know that it isn't made up at least.
Yes, I shall do so.
tactica wrote: Please be my guest :D
Cool, I'll start sometime soon then.
tactica wrote: Lexmark branded keyboards do not belong into a list of IBM P/Ns however. That should go somewhere else.
oh okay, so we're not counting Dell branded Ms, nor Ambras etc too ?
tactica
04 Mar 2018, 22:45
Myoth wrote: oh okay, so we're not counting Dell branded Ms, nor Ambras etc too ?
Right. All those should go in a separate article, the one about IBM P/Ns alone is becoming quite large without clones.
j0d1
04 Mar 2018, 23:04
I hope to contribute to that list one day but for now, I just want to say that this wiki page is VERY helpful so thank you a lot for making it. It's one of the few wiki pages that I have bookmarked and I consult it whenever I encounter an IBM keyboard in the wild. Cheers!
04 Mar 2018, 23:46
It's at the point where a GUI table editor might be more practical :P
Myoth
04 Mar 2018, 23:57
https://www.ebay.de/itm/Vintage-New-IBM ... 1438.l2649
this confirms the 1392366 is Buckling Spring doesn't it ?
tactica
05 Mar 2018, 00:35
Daniel Beardsmore wrote: It's at the point where a GUI table editor might be more practical :P
FYI, there is a Visual Editor for MediaWiki. How well it manages tables, I have no idea - I quit the editor immediately whenever Wikipedia launches it for me.
Myoth wrote: https://www.ebay.de/itm/Vintage-New-IBM ... 1438.l2649
Not any more than wiki/IBM_Enhanced_Keyboard#1392366 does, but whoever wrote that part sounds like he knew what he was talking about so I suppose it is OK to assume it's a BS keyboard :)
Ellipse
24 Jun 2020, 19:25
Someone was chatting with me about IBM part numbers - I thought I'd post the numbers I've found over the years not yet on the DT IBM part numbers wiki page (from what I could see), if someone wanted to update the wiki page.
These are a mix of FRU, Part numbers, and other numbers from IBM and Lexmark. Listed below and attached in Excel format.
Part/FRU/Other Description
1389732 possible space unsaver part number
1615008 IBM 3194 104 key keyboard-possibly sim to 1387033
1742766 possible beam spring
4423001 IBM 3278 keyboard - good - listed as 3287 85 KEY KEYBOARD
5641272 ibm 3101 beam spring possibly
6018100 10 key keypad for 3290
6018109 10 key keypad for 3290
6110348 Model F terminal 122
7361056 66 key 5251 keyboard possibly
7362146 66 key 5251 beam spring keyboard possibly
47044607 alt for F107
47044662 alt part number for Kishsaver 62 key
47044677 alt for F77
41G3564 SSK; industrial
41G3584 SSK; industrial
4704-4607 alt for F107
4704-4662 alt part number for Kishsaver 62 key
4704-4677 alt for F77
1390360 SSK no bezel
1390654 industrial
1391518 SSK-possibly for terminals
1391974 SSK
1391987 SSK
1392575 SSK
1392981 SSK
1392982 SSK insert
1393279 SSK Box Keyboard Carton number
1393490 Keyboard Carton for early 1391401
1393690 SSK-possibly model 30 starter kit
1393990 Keyboard Carton for early 1391401
1394047 SSK
1394981 industrial Spanish
1395241 industrial
1395341 industrial
1396055 industrial
1397690 SSK
1397691 SSK
1428401 Ergonomic
6090817 PC AT Model F
13H6713 Ergonomic
15F8242 IBM Accessory kit box - for 1391401
41G3611 SSK-possible
60G0869 SSK 1370475
61X8767 IBM Accessory kit box - for 1391401
72X7023 IBM Accessory kit box - for 1391401
90X8018 IBM Accessory kit box - for 1391401
90X9252 IBM Accessory kit box - for 1391401
90X9473 IBM Accessory kit box - for 1391401
1393290 SSK FRU - regular 1393290 may not be clicky
1386085 like 1390131
1390119 full size Model M no LEDs
1391990 Regular 101 Key
1396791 Attached Cable; Two Piece Keys; Made in UK
1397449 Flat Cable
1397730 No Logo; Two Piece; Removable Cable
1398609 No logo; like 1391401
59G7981 Removable Cable; Two Piece Keys
60G3571 Attached Cable; Two Piece Keys
71G5791 Attached Cable; Two Piece Keys; Same as 82G2383
801449 PC XT keyboard-confirmed
1389106
1351710 blank caps set
1370580 trackpoint M4-1, M5-1 or M5-2 cable split keyboard mouse ps/2
6480185 1390120 box
additional IBM part numbers.xlsx
(11.47 KiB) Downloaded 1367 times
sharktastica
15 Aug 2020, 00:06
Here are some IBM 3205 Color Display Console F122 and M122 Type I (aka, two-size risers + straight DIN plug) keyboard part numbers, some of which I don't believe are on the wiki yet. The two Japanese Katakana ones are interesting, which are 124-key as per IBM's GA18-2339-1 document.
Annotation 2020-08-14 222632.png (73.08 KiB) Viewed 39692 times
Source: http://bitsavers.org/pdf/ibm/3205/SY18- ... ep1985.pdf
karlmartin95
09 Sep 2020, 15:33
IBM 5281 Keyboard (Beamfoot) Spanish Layout
P/N 5642540
MFI 7361670
7640025KE (last weird number on the back of the keyboard)
shine
16 Dec 2020, 11:00
IBM 8775 spanish - data entry (3276 alike) beamspring keyboard
P/N 8543019
shine
14 Jan 2021, 14:55
IBM 3101 spanish keyboard
P/N 5640441
inozenz
16 Apr 2021, 12:48
I have this thing here.
The Terra branding is really unique and beautiful, tbh i have searched the forum but wasn't able to find anything about it.
Sadly the partnumber is cut off at the end, but i think its something like 139576X.
Maybe someone knows the exact partnumber?
Is there a guide for stuff like that?
1395764 seems to be a model m122, but has blue label, while this one has a grey label. I have a few Model M with grey label and different dates and according to the weight of it my guess is around 1989 maybe even 1988.
It is slightly heavier then the rest, but that is due to the attached cable.
feltel
17 Apr 2021, 17:02
Wortmann with its brand name Terra is a german computer manufacturer, still operating today. See https://de.wikipedia.org/wiki/Wortmann_AG
They are mainly producing budget oriented equipment and PCs. Sure the keyboard came with the logo attached? Maybe someone glued it on back in the day.
inozenz
17 Apr 2021, 19:25
feltel wrote: 17 Apr 2021, 17:02 Wortmann with its brand name Terra is a german computer manufacturer, still operating today. See https://de.wikipedia.org/wiki/Wortmann_AG
I bought it this way, but it really was glued on.
At first i thought it was welded because it was so tough to even lift it up.
Then I used a really thin and sharp knife and risked damaging it, but it came off.
I put the Terra branding back on the keyboard but moved it to the upper right corner.
The beige color matches perfectly maybe it was meant to be on the board maybe it wasn't, i really don't know.
But the board is still not common here in Germany, since i couldnt find any board with the same part number.
But i sure would want to know more about it, thanks for the wiki.
