I'm using a Soarer's Converter on a terminal Model M on a Windows 10 Home build 15063 machine. Everything works great except I can't get the Menu key to work. When I use hid_listen to get the scan code I get +93, which is LANG_4. But no key registers in Switch Hitter when I press it after remapping the keys. Everything else works as it should. Here is the code that I used:
remapblock
NUM_LOCK PAD_SLASH
ESC NUM_LOCK
F13 ESC
PAD_PLUS PAD_ENTER
PAD_ASTERIX PAD_PLUS
PAD_MINUS PAD_PLUS
SCROLL_LOCK PAD_ASTERIX
EXTRA_SYSRQ PAD_MINUS
LANG_4 MENU
F23 PRINTSCREEN
F24 LGUI
endblock
Any help would be appreciated. Thank you!
