Fixing clicky Alps inconsistent actuation point
M4dn3ss
12 Mar 2018, 14:34
I have a batch of clicky SKCM Alps that actuate before the click. I tried "fixing" one by pressing the switchplate leaf to bend it slightly back, and when I tested it, it actuates very close to the click when pressed from directly above. However, if I press the switch from an angle it still actuates before the click.
What is the best way of making the actuation point more consistent (less angle-dependent) on SKCM Alps switches? Which part of the contact leaf should be bent to ensure a consistent actuation point? (see diagram attached)
Wodan
ISO Advocate
12 Mar 2018, 15:09
Holy shit I wouldn't bend around ANY switchplate leaves!
The only thing you I would consider tweaking in an Alps switch is the clicky/tactile leaves
But that's what you get when you use a discrete component to create the click - it potentially decouples from the actuation ...
M4dn3ss
13 Mar 2018, 05:41
I thought bending the leaf was the "standard" way of fixing up stubborn Alps switches is it not? Especially when dealing with old boards that have been heavily used or stored badly where the click/tactile leaf or contact leaf might have gone out of shape.
keyboards-f2/need-help-with-an-alps-whi ... 15732.html
orihalcon
13 Mar 2018, 14:16
If those switches were ever disassembled previously, check and make sure the slider isn’t rotated 180 degrees. It will always actuate before the click if it is. I believe the notched side faces the switch plate, but would have to open a switch to confirm.
Wodan
ISO Advocate
13 Mar 2018, 14:25
M4dn3ss wrote: I thought bending the leaf was the "standard" way of fixing up stubborn Alps switches is it not? Especially when dealing with old boards that have been heavily used or stored badly where the click/tactile leaf or contact leaf might have gone out of shape.
Hm okay that still sounds like a terrible idea. no way will you be able to consistently bend all the switch plate leaves to a point where they all have a uniform actuation again.
M4dn3ss
13 Mar 2018, 14:55
You would have to adjust very slightly and keep testing after every adjustment
