IBM 3101 label replicating: part no. and font
PlacaFromHell
21 Mar 2018, 00:17
Hi guys. I was thinking about replicate the paper label of my 3101, It was broken so some information has been lost. I wonder if someone has the first numer of my part numer and also looking for a similar font. I replaced the lost information with a "?"
Myoth
21 Mar 2018, 00:19
the pn's missing caracter is most probably 2 and the manufacturing date's missing character 0
PlacaFromHell
21 Mar 2018, 00:21
Myoth wrote: the pn's missing caracter is most probably 2 and the manufacturing date's missing character 0
Thanks, I was thinking about 0 when I saw one with this.
Myoth
21 Mar 2018, 00:24
oh wait then I must be wrong, I thought it was months but this is most probably weeks (since there is no 40th month) so I can't help you it could be 05, 15, 25, 35 or 45, choose the one you prefer I guess :P
P.S. : I thought my displaywriter was from June 1981, little did I know I was wrong !!
PlacaFromHell
21 Mar 2018, 00:27
The part no. was the important fact here, just to mantain his identity :D Now I should found a similar font
Myoth
21 Mar 2018, 00:29
weeeeell for the part number I guessed it was 2 but you can check on the [wiki]IBM part numbers[/wiki] list .. which I can't at the moment :/
CTRL + F-ing is a really useful feature !!
PlacaFromHell
21 Mar 2018, 00:32
Looks like it's 5 8-) Nice idea!
31 Mar 2018, 17:25
I did something similar with my Display Writer. I still need to get a proper print done to finish it though. If you get me a high quality scan or image I should be able to help with the fonts. In my case the fonts needed were not free ones.
PlacaFromHell
31 Mar 2018, 22:08
JP! wrote: I did something similar with my Display Writer. I still need to get a proper print done to finish it though. If you get me a high quality scan or image I should be able to help with the fonts. In my case the fonts needed were not free ones.
Thanks for you help, I already destroyed the label to paint the case. It was too much damaged to get accurate information anyway (as I said in other thread, I think my keyboard was on the sea some time). I found this one that has the same format. If I remember well it is from a keyboard which match perfectly with mine.
I can't decide about pay for a professional label or paint it to preserve the information.
Engicoder
01 Apr 2018, 07:03
A little late, but the blocky font on the right hand side is called "OCR-A" https://en.wikipedia.org/wiki/OCR-A
PlacaFromHell
01 Apr 2018, 07:17
Oh man, I love you
