Hello everyone,
The round 5 group buy is on.
This group buy is for hot-swappable MX-based switches keyboards and optical switches keyboards with full RGB backlit (user can DIY full RGB light effects completely), multi-layer full programmable.
This group buy include 5 models: iGK61, iGK61P, iGK62,iGK64 and iMK11
iGK61: 61-key poker layout, hot swappable MX-based switches
iGK61p: 61-key poker layout, hot swappable optical mechanical switches
iGK62: 62-key with dedicated arrow keys, hot swappable optical mechanical switches
iGK64: 64-key with dedicated arrow keys, hot swappable MX-based mechanical switches
iMK11 104-key hotswap optical switches mechanical keyboard
iGK61 and iGK64 - a FANTASTIC starter keyboard:
1.The hotswap sockets are perfect for those who are interested in trying new switches. This is great!
With visual software driver, multi-layer programmable and DIY full RGB lighting effect, operating easily. This is a super-value keyboard!
2.We supply multi custom kits and DIY PCB parts, for people who are just getting in the hobby, smart buy easily, also are perfect!
iGK61p and iGK62 - the future keyboard:
Hotswap optical switch keyboard, as a mechanical keyboard enthusiast, you should have and try it!
Optical switch is a new kind of switch, different from MX mechanical switch.Introduction of optical switch
GB main page
iGK61 GB here: pre-assembly finished product, multiple custom kits, DIY PCB...
iGK61P GB here: pre-assembly finished product, multiple custom kits, DIY PCB...
iGK62 GB here: pre-assembly finished product, multiple custom kits, DIY PCB...
iGK64 GB here: pre-assembly finished product, multiple custom kits, DIY PCB...
iMK11 GB here
Keyboard Switches GB here: Cherry MX RGB switch(blue,red,brown,silent red,silver), Gateron RGB switch(blue,black,red,brown,yellow,silent red,silent brown,silent black), Gateron optical switch(black,red,blue,brown,silver)
This round group buy adds white ABS keyboard case and blossom pbt keycaps as optional
iGK61 custom kits with white ABS case
iGK64 custom kits with white ABS case
iGK64 pre-assembly product: with white ABS case and blossom pbt keycaps
iGK64 pre-assembly product: with red aluminum alloy metal case and blossom pbt keycaps
R5 groupbuy for iGK6x keyboards,custom kits,PCB, Cherry/Gateron switch
ingeniousmonkey
- Main keyboard: mechanical keyboard
- Main mouse: wireless mouse
- Favorite switch: blue switch
- iGK64: compact 60% RGB keyboard with red aluminum alloy metal case and pbt dye-subbed keycaps
- iGK64-hotswap-switch-RGB-keyboard-set-1b.jpg (148.24 KiB) Viewed 2201 times
ingeniousmonkey
The round 5 group buy will be closed in 24 hours
