Keep in mind shipment is from Canada. Feel free to send me offers.
For sale:
-76x 67g Zealios (from R4 if I'm not mistaken). These were desoldered from my ergodox so I could put box navies into it. All the pins are in good condition, nothing bent or broken.
Asking $50 SOLD
-80x aristotles in MX housings with switch stickers installed. They're using the stock aristotle spring, so I'm not certain what the weight is. It's similar to MX blue/brown.
-20x MX clears with switch stickers installed
Asking $40 for the aristotles, $7 for the MX clears. $45 if bought together. SOLD
-110x MOD-H tactile switches
Asking $64 SOLD
-Dactyl-Manuform modified to adhere more closely to the ergodox layout. Case is printed with PETG, bottom plates were printed later out of PLA. Switches are box royals with box navy springs. The springs have some lube to get rid of ping. All the switches have the x-axis nubs shaved down, so none of the switches should be too tight. At worst you may need to use the plastic sheet trick in case some switches are too loose. TRRS/USBcables not included.
Asking $200 OBO SOLD
-120x Zealencios. Put them on my ergodox once, but decided I actually preferred the board sound/feel without them.
Asking $40 OBO SOLD
-74x zeal v2 67g with novelkeys cream stems in them. So these are essentially tealios with a different colored stem. I also have the 70g springs from creams if you would prefer those in them instead. They're quite smooth, enough so that I have a hard time telling whether these or stock creams are smoother. The 67g springs are noticeably pingy though. I can lube them for a little extra per switch.
Asking $55.50 ($0.75/pc) SOLD
-Dactyl-Manuform, 5x7 layout with (retooled) box navies. Case is printed with grey PETG. Switches are hand-wired directly to the pins and hot-glued in place. Case has been modified on the thumb cluster so that keycaps don't hit it. Bottom plate has 20mm circular feet. Dev/tty keycaps not included. Can include PBT DSA grey/black keycap set for $25 extra.
Asking $200 SOLD
-Dactyl-Manuform, 5x7 layout with holy pandas lubed with 3203. Case is printed with dark grey PLA. The case design has a few modifications compared to the other two; different thumb cluster allowing clearance for all keys, different pro-micro/trrs holder as well. The switches are wired up using Amoeba PCBs (pic of the board before final soldering). Can include PBT DSA grey/black keycap set for $25 extra.
Asking $300 SOLD
-Dactyl-Manuform, 5x7 layout with 78g V2 zilents lubed with krytox 103/205. Case is printed with grey PETG. Switches are hand-wired directly to the pins and hot-glued in place. Case has been modified in a few places so keycaps don't rub against it (on both thumb clusters and around the -/_ key on the right half). Bottom plate has large rubber pads for a bit of extra sound absorption.
Asking $250 SOLD
-Dactyl-Manuform case, 5x7 layout printed from translucent sea green PETG filament. Pics don't really do the color justice, it's a nice translucent teal in person. Included would be the hardware needed to build the board: heat-set inserts for the case, bottom plates, screws, trrs breakout boards, and pro-micros. I can include 74x amoeba PCBs and diodes for an extra $13 if you wish to wire the board up using those. I can include a braided trrs cable for $2.50 or a micro-usb cable for $4. If you'd like a finished build with this case feel free to message me.
Asking $60 SOLD
-MT3 dev/tty1 keycaps. Specifically the base kit, ergodox kit, and ortho kit. The only keys that saw any use are the ones shown on the dactyl-manuform below. The other keys are all unused.
Asking $100 SOLD
-Dactyl-Manuform, 5x7 layout with NK creams lubed with krytox 205g0. Case is printed with blue-grey PLA. Some more build pics here. Switches are wired up using amoeba PCBs. The pro-micro & trrs jack use a separate holder I designed. Does mean that right angle trrs cables probably won't fit since the jack is recessed a bit. Bottom plates have a layer of sorbothane on it to absorb sound and give the board a bit of extra weight. I can include a braided trrs cable for $2.50 or a micro-usb cable for $4. MT3 Godspeed keycaps not included.
Asking $290 SOLD
-Dactyl-Manuform, 5x7 layout with crystal jades (springs are lubed to reduce ping). Case is printed in military green PLA. Here's an internal shot. Switches are wired up using amoeba PCBs. The pro-micro & trrs jack use a separate holder I designed. Does mean that right angle trrs cables probably won't fit since the jack is recessed a bit. I can include a braided trrs cable for $2.50 or a micro-usb cable for $4.
MT3 dev/tty not included.
Asking $245 SOLD
-Dactyl-manuform, 5x7 layout with crystal jades (springs are lubed to reduce ping). The thumb cluster is one I designed. The goal was to use all the same keys as the default thumb cluster but only requiring the thumb to move one position left or right to hit everything. Case is printed from prusament pearl mouse. Switches are wired up using amoeba PCBs. The pro-micro & trrs jack use a newer separate holder. The trrs jack is brought up to the back of the case so right angle trrs cables will work just fine. I can include a braided trrs cable for $2.50.
Asking $245 SOLD
-Dactyl manuform, 5x7 layout with T1s lubed with tribosys 3203 & filmed with TX films. Keycaps are blank PBT DSA. Switches are wired up using amoeba PCBs. Case is printed with prusament gentleman's grey filament. Doesn't really show in this pic but at certain angles the filament has this very nice green sheen to it. Under most conditions it looks like a dark blue-ish grey. Most of the parts (save for the right hand case) were printed using my old printer, so the print quality isn't quite as nice as it is with the prusa. So to compensate I'll eat the paypal fees. I can include a braided trrs cable for $2.50. If you don't want the keycaps just subtract $28 from the asking price.
Asking $298 SOLD
-Dactyl-manuform, 5x7 layout with drop holy pandas lubed with tribosys 3203. Keycaps are blank PBT DSA. Switches are wired up using amoeba PCBs. Some switches weren't 100% secure in the case so hot glue was used to ensure they don't wobble. Case is printed with prusament galaxy black PETG. Comes with a braided trrs cable. Here are some other angles. If you don't need the keycaps just subtract $28 from the asking price, if you don't need the trrs cable then subtract $2.50.
Asking $348 SOLD
-Krytox 205g0. I've lubed about 150 switches very lightly, so there's still likely more than 4mL left in this tub.
Asking $9 SOLD
-24x box navy switches. These are pre-retool navies so they have the thick x-axis. Easily solved if you have a tool like a cruciformer to shave the stem down, that or a small chisel will also work.
Free, just pay for shipping. SOLD
-80x box navy switches. These switches (along with most of the crystal jades) all have a weaker tactility than they should. After comparing with the sprit clickbars, these more closely resemble the 20g clickbars in feel than the 30g clickbars they should. So these are essentially 'medium' clickbar switches.
Asking $25 SOLD
-86x crystal jade switches. The vast majority of these switches have a weaker clickbar as described for the navies. They more closely resemble 20g clickbars rather than the 30g they should. There are a few that are a bit more tactile, but still not quite the normal level of tactility for thick clickbar switches. So these are essentially 'medium' clickbar switches.
Asking $36 SOLD
-100x Kailh box springs. These are rated for 55g actuation/70g bottom out.
Asking $10 SOLD
-Sprit clickbars of all weights. Each of them has approx. 40x clickbars, give or take.
Asking $6 SOLD
--Dactyl-Manuform, 5x7 layout with tangerines. The tangerines have been filmed with 0.15mm clear TX films, lubed with 205g0 and the stems have been swapped with invyr v1 UHMWPE stems. They are incredibly smooth, and there's no 'stick-slip' that I can detect with any of the switches. I can throw in the extra v1 invyr stems I have for free if so desired. Here is a nude shot and here is an internal shot. Case is printed with prusament galaxy silver filament. Comes with a braided TRRS cable and blank grey/black PBT DSA keycaps. If you don't need the keycaps or TRRS cable just subtract $25 or $2.50 from the asking price respectively.
Asking $333 SOLD
-Dactyl-Manuform, 5x7 layout with 68g boba U4Ts. Here's a nude shot. These U4Ts use a linear base rather than a tactile one, so the switches have more of a medium tactility. They've been lubed with tribosys 3203. Keycaps are blank PBT DSA. Case is printed with prusament galaxy black PETG. Uses the same PCBs as my other dactyls. Comes with a braided TRRS cable. If you don't need the keycaps or TRRS cable just subtract $25 or $2.50 respectively from the asking price.
Asking $314 SOLD
-Ploopy trackball. Running QMK firmware. Used for a few weeks to get used to it but trackballs just ain't for me. The ball bearing rollers are quite smooth now after breaking in. Red buttons & base were printed by myself. Includes USB cable and a few extra printed parts.
Asking $125 SOLD
-Dactyl-Manuform, 5x7 layout with 68g bobagums. The bobagums have been lubed with 205g0. Keycaps are blank PBT DSA. Case is printed with prusament galaxy silver. Comes with a braided TRRS cable. Uses the same PCBs as the dactyl-manuform with holy pandas. If you don't need the keycaps or TRRS cable just subtract $25 or $2.50 respectively from the asking price.
Asking $321 SOLD
-Dactyl-Manuform, 5x7 layout with silent alpacas. The silent alpacas have been filmed, lubed with krytox 205g0, and swapped to 70g springs. Keycaps are blank PBT DSA. Case is printed with fillamentum wizard's voodoo. Hard to capture in pictures but depending on the light it'll have either a blue or purple sheen to it. This pic shows off the purple a little better. Uses the same internal PCBs as my other dactyls. Comes with a braided TRRS cable. If you don't need the keycaps or TRRS cable just subtract $25 or $2.50 respectively from the asking price.
Asking $330 SOLD
-Dactyl-Manuform, 5x7 layout with drop holy pandas. The pandas have been lubed with tribosys 3203. Keycaps are blank PBT DSA. Case is printed with prusament gentleman's grey. Under certain light it has a beautiful green sheen to it. Normally its color is a blue/grey. Here is an internal shot. Comes with a braided TRRS cable. If you don't need the keycaps or TRRS cable just subtract $25 or $2.50 respectively from the asking price.
Asking $344 SOLD
-Dactyl-Manuform, 5x7 layout with glorious pandas. The pandas have been lubed with tribosys 3203. Keycaps are blank PBT DSA. Case is printed with prusament galaxy black PETG. Here is an internal shot. Comes with a braided TRRS cable. If you don't need the keycaps or TRRS cable just subtract $25 or $2.50 respectively from the asking price.
Asking $330 SOLD
-Dactyl Manuform, 5x7 layout with boba silent linears. The bobas have been lubed with 205g0 & swapped to 70g springs. Aside from the color of the switch these are basically identical to bobagums. Case is printed with prusament gentleman's grey. Normally it looks like a dark blue/grey, but in certain lighting there's a green sheen to it. Internally it uses the same PCBs as this board. Keycaps & trrs cable are not included. I'll be getting more keycaps & cables in the coming weeks however.
Asking $297 SOLD
-Custom aluminum ergodox. PCB is from falbatech. Currently runs QMK with the default ergodox ez layout. Switches are box navy with box royal springs (70g bottom out). These are pre retool box navies which have had their x-axis shaved down to ensure they don't crack keycaps. At worst some caps may be loose, but placing a thin plastic sheet between the cap & stem should fix that. Tenting angle is about 20 degrees. Weighs a little over 7lbs total. If needed I can throw in a TRRS cable for free.
Asking $200 SOLD
-SA Retro from Signature Plastics. These are from the group buy that ran in 2015. Includes the Retro Burgundy & Ergo kits. The caps which were in use (shown on the ergodox here) show obvious signs of use like shine. The caps not shown on that ergodox are unused. Unfortunately the used caps fell victim to pre-retool box switches, so a number of them have stressed or cracked stems.
Asking $150 SOLD
Asking $50 SOLD
- IMG_20180424_202721.jpg (905.32 KiB) Viewed 24888 times
- IMG_20180325_155003.jpg (1.23 MiB) Viewed 25104 times
Asking $64 SOLD
- MOD-H.jpg (1.09 MiB) Viewed 23683 times
- IMG_20181107_161311.jpg (1.22 MiB) Viewed 23590 times
Asking $40 OBO SOLD
- IMG_20180418_232215.jpg (867 KiB) Viewed 25018 times
- IMG_20191119_192118.jpg (890.78 KiB) Viewed 19266 times
Asking $200 SOLD
- IMG_20191230_173818.jpg (1.07 MiB) Viewed 18146 times
Asking $300 SOLD
- IMG_20191230_173848.jpg (975.73 KiB) Viewed 18146 times
Asking $250 SOLD
- IMG_20191230_173750.jpg (1.26 MiB) Viewed 18146 times
Asking $60 SOLD
- IMG_20200401_164215.jpg (1.47 MiB) Viewed 17112 times
Asking $100 SOLD
- IMG_20200506_171658.jpg (977.49 KiB) Viewed 16477 times
- IMG_20200506_171718.jpg (1.04 MiB) Viewed 16477 times
- IMG_20200506_171807.jpg (943.92 KiB) Viewed 16477 times
Asking $290 SOLD
- IMG_20200224_180732.jpg (907.79 KiB) Viewed 17484 times
Asking $245 SOLD
- IMG_20200503_182043.jpg (812.26 KiB) Viewed 16625 times
Asking $245 SOLD
- IMG_20200812_163406.jpg (1.14 MiB) Viewed 14740 times
Asking $298 SOLD
- IMG_20200825_185025.jpg (832.09 KiB) Viewed 14130 times
Asking $348 SOLD
- IMG_20200903_154021.jpg (830.02 KiB) Viewed 13995 times
Asking $9 SOLD
- IMG_20200921_174054.jpg (533.89 KiB) Viewed 13765 times
- IMG_20200921_174116.jpg (779.81 KiB) Viewed 13765 times
Asking $25 SOLD
- IMG_20200921_173615.jpg (823.33 KiB) Viewed 13765 times
Asking $36 SOLD
- IMG_20200921_230618.jpg (613.78 KiB) Viewed 13757 times
Asking $10 SOLD
- IMG_20200921_173647.jpg (837.65 KiB) Viewed 13765 times
Asking $6 SOLD
- IMG_20200921_230340.jpg (857.35 KiB) Viewed 13757 times
Asking $333 SOLD
- IMG_20210201_180344.jpg (900.19 KiB) Viewed 12436 times
Asking $314 SOLD
- IMG_20210408_195119.jpg (923.32 KiB) Viewed 11175 times
Asking $125 SOLD
- IMG_20210120_170013.jpg (442.5 KiB) Viewed 12574 times
Asking $321 SOLD
- IMG_20210406_190408.jpg (927.42 KiB) Viewed 11230 times
Asking $330 SOLD
- IMG_20210430_151203.jpg (983.87 KiB) Viewed 10699 times
Asking $344 SOLD
- IMG_20210406_190343.jpg (840.09 KiB) Viewed 11230 times
Asking $330 SOLD
- IMG_20210502_194508.jpg (944.02 KiB) Viewed 10602 times
Asking $297 SOLD
- IMG_20210625_162114.jpg (1.09 MiB) Viewed 9604 times
Asking $200 SOLD
- IMG_20210704_195857.jpg (1.06 MiB) Viewed 9441 times
Asking $150 SOLD
- IMG_20210706_183521.jpg (656.19 KiB) Viewed 9387 times
- IMG_20210706_175806.jpg (696.31 KiB) Viewed 9387 times
