Hi Kissu,
i have bin in to mechanical keyboards for years now,,but only now starting to gather hardware to do my own assembly not build that's on a whole different level.. Even as a 40yr i'm learning new stuff every day...
Every time i think i'm done spending $$ on hardware i think i need more get's added to my shopping cart..
There are a couple of items i do want to share that could be useful. In the months of research i have done i came up with the best direct heating iron that is affordable and that is the TS100. i ordered it from banggood.. if you don't know about it just watch "Louis Rossmann" on youtube talk about it ..
A comparable direct heating system would be the Hakko FX-951..or if you budget is limitless there is also JBC..
of course there is not such thing as perfection or without flaw.. And as far as i can see there is only one instance of something going bad with the TS100 and that's related to the tip shorting or something else related to the tip not being 100% causing the Mosfet to malfunction.. contacting support will get you grate service and a replacement leaving you with the opportunity to fix the broken one and end up with two TS100.. so no danger dear..Again this almost never happens.
i also bought a desoldering station from
www.aoyue.eu but i think that's a bit overkill..
I got an older model because i wanted a AC pump and they switched to DC pumps in all the current models..
The problem i had was that my model had a nob to control the temperature instead of digital interface..
So i went looking for something that could tell me the temp of my desolder gun..
Hakko has a soldering iron temp tester but that costs way way to much..
So i got the Chinese on for €10 and it works great (already tested). it's the DANIU FG-100 from banggood.
Here's the link:
https://www.banggood.com/DANIU-FG-100-S ... rehouse=CN
And sum spare sensors (don't get stuck without them €3,41
https://www.banggood.com/Hakko-Sensor-1 ... rehouse=CN
btw if your in EU like i am.. grab you solder from these guys.. tmw.eu
i got leaded Sn63Pb37
brand Stannol it's like €17,30 for 500grams will last you a bit.. if i was to buy that here in The Netherlands i would pay double.. and it's not cheap Chinese crap but a good brand.. Here you don't want to cut costs..
Also grab sum flux, sum Isopropylalcohol to make your own flux cleaner (search youtube)..
and if you do go with the TS100 from banggood.. buy a good power supply not from china.. don't skimp on that..
i got this one from tme.eu GST90A24-P1M
what you need to know is that the jack needs to be 5.5 /2.5 if you have an old laptop supply that will also do..
good luck mate..
