IBM Model M Ninja M modification process
cdaman
- Main keyboard: Model M
Hello guys,
I'mma newbie from Thailand
I recently purchased this keyboard from one of my friends that really got me into the mech keyboard community. Hes the one who do all the work in this Model M. As an professional full-time architect/interior design, he has a part-time of modified junk, useless, broken keyboard for hobbies. And I think one of his masterpiece and I wanted to purchase this keyboard from him for years, until recently, he says yes!!! So I can fully says its mine. However, he doesn't speak well English, but he had a well documentation of his work in his page.
cdaman
This is basically a modified IBM Model M Terminal in which mixed with Chicony KB5181's frame as the surround frame around the IBM. All the material use are very low cost, he told that the cost of making this work is only around $21USD, but the amount of time he actually spend on the keyboard to make it work like new is enormous. If you noticed, he use the white paint, to mimic the Japanese character in ninja style font on the keycap. The inspiration is pretty obvious, its from Kawasaki Ninja motor bike
Yes, the IBM Model M ninja M!
green-squid
- Main keyboard: --
- Main mouse: --
- Favorite switch: --
Looks glorious man!
- cookie
- Main keyboard: HHKB Pro 2
- Main mouse: MX Master
- Favorite switch: Topre
I highly appreciate all the work and effort that has been put into this keyboard!
The result although might not appeal to the borad audience of this particular forum, which is mainly into genuine keyboards. Especially if they are older ones, like the model M you have.
Don't be discouraged though! Feel free to stick around ask questions post your projects! Who knows, a certain taste might evolve?
You might consider www.geekhack.org or /r/mechanicalkeyboards as well, this audience is more into flashy boards like yours.
Cheers and welcome!
Cheers and welcome!
- Brett MacK
- Main keyboard: SGI Granite
- Main mouse: Logitech G403
- Favorite switch: White Clicky Hi-Tek 725
As someone who normally isn't into heavily modified vintage keyboards, this is an amazing keyboard. Very impressive work. He payed attention to every little detail, and it really payed off with the finished project.
codemonkeymike
- Main keyboard: Ergodox
- Main mouse: Razer Naga
- Favorite switch: Box Jade
Indeed impressive work!
- Elrick
- Main mouse: MX518
Can see the Kawasaki in this keyboard, excellent work.
Shame the company itself didn't get into any promotional work using keyboards, especially Model-M's
- clickykeyboards
- Main keyboard: 1395682, IBM model M 1985
- Main mouse: Logitech G500 weighted
- DT Pro Member: 0233
Very clean, elegant and tastefully done.
It is nice to see how much detail work it must have taken to apply masking tape to the internal barrel plate to ensure that the individual key stems do not stick or rub on the added layers of paint.
Glad to see that you used 6mm long screws applied from the inside surface of the keyboard and kept the screw heads on the inside of the keyboard versus using nuts and 8mm long bolts.
Did you hand paint the legends on the side surface of the keys?
6664
- Main keyboard: Chicony KB-5191 apls
- Main mouse: Oker
- Favorite switch: apls
yes. paint by handclickykeyboards wrote: Very clean, elegant and tastefully done.
- DSCF1051 - Copy.JPG (1.12 MiB) Viewed 7979 times
orihalcon
- DT Pro Member: 0190
Very cool!
My only suggestion would be to start with a black barrel plate instead of spray painting a white one. I get that the keyboard in question was already white, but black ones are pretty easy to find. Spray paint could potentially add some gritty feel to some keys if not masked down far enough and not having to paint or mask at all would save a ton of time as well
savantstrike
For a neon green color scheme, the design is actually quite elegant.
This was a board rescued from the scrap heap, not a mint condition prize - so I think the reception here should be positive. People here only get upset when a good vintage board gets modded for no reason.
- just_add_coffee
- Main keyboard: Model F AT, Batwing Ergodox
- Main mouse: Microsoft Trackball Explorer 1.0
Very, VERY cool and inspiring! Thank you for sharing this!
- digital_matthew
- Main mouse: It's a Secret.
As an IBM keyboard purist, I must acknowledge the great work that went into this keyboard. The Ninja scheme actually works pretty well on this, and the lock lights under the wire screen is a great touch that I would like to see on other "gamer" keyboards. Nice!
- livingspeedbump
- Not what they seem
- Main keyboard: Realforce 87u 55g
- Main mouse: CST Trackball
- Favorite switch: 55g Topre
- DT Pro Member: 0122
This is totally bonkers. If you'd have described what you did to me without pictures, I'd just assume I'd hate it.
But golly, this is great! Truly love this.
- webwit
- Wild Duck
- Main keyboard: Model F62
- DT Pro Member: 0000
#dta2018 Best mod
- digital_matthew
It just goes to show that no matter the style, if it's well thought out and the craftsmanship is strong then you'll get a good result.
