Just did some experiments with spray can paints on my model f XT
- ag36
- Main keyboard: Model M
- Main mouse: MX ERGO
Restored my first XT this week, did some experiments with rustoleum.
Post polishing
Before polishing
Step is:
Matte primer, matte metallic silver, metallic gunmetal, matte clear, polishing paste, old towel.
Post polishing
Before polishing
Step is:
- snacksthecat
- Main keyboard: SSK
- DT Pro Member: 0205
Looks great dude. I don’t wanna be a wet blanket but I think I like it even better before polishing. Either way, light years better than any paint job I’ve ever done!
- ag36
- fohat
- Elder Messenger
- DT Pro Member: 0158
I have used Rustoleum's metallic and hammered finishes exclusively for the last few years. I love them AND they can often hide minor blemishes!
Unfortunately, in the US many of the best colors have these weird-ass top handle/nozzles that are awful, in my opinion, because they start out putting out blobs and and don't give a consistent fine spray until they have been running for a second or more.
green-squid
- Main keyboard: --
- Main mouse: --
- Favorite switch: --
Turned out great, I wish I could buy paint like this in Hungary. The Acrylic green paint I painted my zenith plate with is very easy to sratch off.
'Matte primer, matte metallic silver, metallic gunmetal, matte clear, polishing paste'
And looks like you have to apply a lot of other things to get a good result. What if, let's say, I just wanted to paint an F XT plate blue or gold and have the paint not come off?
Also, may want to get a replacement badge: workshop-f7/reproduction-logo-badges-fo ... bm%20badge
- ag36
I think the key is to let the spray can rest longer after each pass to ensure better air pressure and shake it again before use but I am not sure if this applies to US ones, the "blobs" are likely caused by low gas pressure or condensed paint.fohat wrote: I have used Rustoleum's metallic and hammered finishes exclusively for the last few years. I love them AND they can often hide minor blemishes!
green-squid wrote: Turned out great, I wish I could buy paint like this in Hungary. The Acrylic green paint I painted my zenith plate with is very easy to sratch off.
You need to apply clear coat and primer for better adhesion and hardness also use oil based paint if you can, also degrease the item you want to paint.
- ag36
ag36 wrote:I think the key is to let the spray can rest longer after each pass to ensure better air pressure and shake it again before use but I am not sure if this applies to US ones, the "blobs" are likely caused by low gas pressure or condensed paint.fohat wrote: I have used Rustoleum's metallic and hammered finishes exclusively for the last few years. I love them AND they can often hide minor blemishes!
Thanks for letting me know about the badge, unfortunately it don't have "personal computer" print for XT but still nice to know it exists.green-squid wrote: Turned out great, I wish I could buy paint like this in Hungary. The Acrylic green paint I painted my zenith plate with is very easy to sratch off.
Inspiration was from my non stick frypan
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
I really like the Rustoleum Paint+Primer, makes painting a breeze.
- Tha_Pig
- Main keyboard: EagleTec KG040
- Main mouse: Logiteck trackball
- Favorite switch: Cherry MX blue
It looks beautiful. Great job.
- Elrick
- Main mouse: MX518
All the 2-Pack Clear Epoxies when hardened over a few days are very tough. I've even tried to damage it with a pick axe once and only the metal panel was disfigured but the coating held it's shape, did not even chip or crack.
Just surprised with what they're releasing today.
- DT Pro Member: 0167
Oh no you poor XT , what did that mean man do to you ! He cut bits off !
The paint looks good tho , its not what i would use on a case but it would make a hell of a paint job for a case IMO.
- ag36
This deal is getting worse all the time
It's not quite done, the filler I used shrinked after I finished clear coat but I got tired for now... also too much dust on it. I need to get some rest
- IMG_20180620_181051.jpg (3.72 MiB) Viewed 7597 times
- IMG_20180620_180916_1.jpg (4.65 MiB) Viewed 7597 times
That is PLATE not case , it would make a hell of a paint job for a plate.
In fact, it would be a good match for my dell AT101w in an SGI case with the new PCB. As its like granite but dark
- Wingklip
- Main keyboard: IBM 3178 Model F C2
- Main mouse: G502 Logitech Proteus core
- Favorite switch: Beam/plate spring
I've been using the 2x gloss paints from rusto but they seen to scratch easily and melt after contact with meth and oil.
Am I doing something wrong here? I've read that the primer is included in the paint
- Wingklip
2 WEEKS??????
I mean, if I rest my wrist on the keyboard, the painted area likes to start melting into oils from my hands. Same happens when I use methylated Spirits
- TuxKey
- LLAP
- Main keyboard: Leopold FC660C, Leopold FC660M mx-clears
- Main mouse: Apple Magic Trackpad, ducky Secret (PBT mouse)
- Favorite switch: Cherry MX-clear, Topre 45gr/55gr
- DT Pro Member: 0137
i can't tell the difference between my new tada68 alu gray case.. impressive mate..
- ag36
Thanks!
Never ever let painted material touch solvents and always wash your hands before touching any non chemical resilient polymer if you have contacted with any mineral spirit or petroleum distillates.
- Wingklip
hhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhhh my hands emit body oils
- Wingklip
