Magnavox Videowriter review (Alps SKCM Brown)
- depletedvespene
- Main mouse: Logitech G700s
- DT Pro Member: 0224
Good video, although I wish you had talked a bit more about the Alps SKCL compact switches.
About that... considering that these and the 5140 keyboards are usually harvested for their brown Alps switches, to be used on 60% builds, and that the SKCL compact ones (plus their caps) seem to be ignored, how about... collecting a few sets of those and making a smaller (compact-er) keyboard meant for small hands (like those of kids, just like you had mentioned in the Bigkeys LX video)?
- Chyros
SKCL Compact have fairly limited uses unfortunately. The thing you describe would need.... inordinate amounts of custom materials to function xD .depletedvespene wrote: Good video, although I wish you had talked a bit more about the Alps SKCL compact switches.
- Bass
- Main keyboard: IBM Model F104 "Unsaver"
- Main mouse: Logitech G9x
- Favorite switch: Beamspring / Capacitive Buckling Spring
- DT Pro Member: 0206
Nice to see you finally tackle brown alps. I actually got some brown alps boards myself recently including a videowriter and I also wish I could easily convert it instead of using it as a switch donor. The layout is actually pretty decent but more importantly it sounds much better in comparison to an Alps64 custom I have with the same switches. Alps definitely benefits from beefy plastic enclosures in regards to sound.
- //gainsborough
- ALPSの日常
- DT Pro Member: 0188
So, Chyros, the big question is how do these rank in your tactile alps list?
NeXT is SKCM cream, right? (see what I did there?)
- Chyros
Yes, an SKCM Cream NeXT will probably be next, if only because I've done almost all the other types of Alps by now xD . Where I'm going to get a pristine one of them, I'm really not sure yet xD .
I still prefer SKCM Orange to these, mostly due to the weighting. They are excellent tactile switches regardless
