Looking for knowledge/expertise on a mid 80s keyboard switch.
Surpex
- Main keyboard: DZ60
- Main mouse: Logitech G305
- Favorite switch: MX Black
Hey guys. I bought an Olympia Electronic Compact typewriter with the intention of recycling its switches for use in a hand wired board. The problem is, most of the switches have two pins on the bottom, just like MX switches, but some of the switches (like the space bar) have 4 pins. Does anyone know what the deal here is? Do I need to wire all 4 leads?
- 2ter
- Main keyboard: olympia carrera or m from 87, apple M0118 (office)
- Main mouse: wheel mouse optical
- Favorite switch: clicky
probably double action switches: two contacts for the normal keypress, the other two for when you press harder all the way down. is it marquardt butterfly switches (wiki/Marquardt_Butterfly)?
it should have mitsumi standard mechanical and the switches with 4 pins should be wiki/Mitsumi_standard_mechanical_double_action.
Surpex
Unfortunately I don't have a multimeter. I should probably pick one up sometime, considering their utility, though.
This is exactly what they are! I disassembled the switch to check it out, and it definitely has two sets of contacts, and an extra, harder spring. Any suggestions on how I would wire this to a accommodate a modern keyboard?2ter wrote: .
SpacemanToby
- Main keyboard: Alps Typewriter Conversion
- Favorite switch: Alps SKCL Green
You just have to figure out which two pins actuate on the first press and wire those. You can ignore the other two. I've hand wired a mitsumi typewriter conversion actually.
- 2ter
or you could wire it as if it would be two switches and actually take advantage of the switch.
