Hey people.
I just found this old keyboard in my parents garage, does anyone know anything about it? I can't seem to find anything on google. I'm also curious if I can hook this up to my new PC somehow. I think it's a DIN connector but I'm not sure. All I know is that I don't have a reciever for it in my PC. Appreciate any help I can get.
What keyboard is this?
Letho
- Main keyboard: Cooler Master Masterkeys Pro S
- Main mouse: Zowie EC2-A
- Back
- IMG_20180719_155253.jpg (2.62 MiB) Viewed 2165 times
- Front 2
- IMG_20180719_145852.jpg (2.85 MiB) Viewed 2165 times
- Front
- IMG_20180719_145839.jpg (2.84 MiB) Viewed 2165 times
- DIN connector?
- IMG_20180719_155346.jpg (2.92 MiB) Viewed 2165 times
- DT Pro Member: 0167
It looks like dome with slider to me looking at the patent
https://patents.google.com/patent/US4939324
- DT Pro Member: 0011
The manufacturer and model number are right there, and "Key Tronic" is very well known so I find it weird that you did not find much info.
It is a regular old rubber dome keyboard. Nothing special.
There are adapters from the large DIN plug ("AT") to mini-DIN plug ("PS/2") which is still be supported on most desktop PCs.
PS/2 and AT is not a hotswap interface though so you should have your computer turned off when you plug it in or yank it out.
- kbdfr
- The Tiproman
- DT Pro Member: 0010
… and also failed to find the dedicated thread unequivocally named IDENTIFY THE KEYBOARD.
- mark201200
most modern pcs can handle PS/2 hot swap. I don't think that's a problemFindecanor wrote: The manufacturer and model number are right there, and "Key Tronic" is very well known so I find it weird that you did not find much info.
