Hi everyone,
I am wandering the difference between the Das Keyboard 4 Professional for Mac and the "normal" one.
Are the keycaps the only difference between the two keyboards?
Did anyone test it on a Linux or Windows machine?
In other words: would I get a "normal" one changing the keycaps?
Thank you for the help!
Das Keyboard 4 Professional for Mac on Linux/Windows
I’d guess so, yes. Might be a difference in modifier keys too. Macs have Command (which PCs see as Windows key) either side of spacebar, swapped with Alt.
- Blaise170
- ALPS キーボード
- Main mouse: Logitech G502
- DT Pro Member: 0129
If you change the layout in system settings it will work fine. I switch between a Windows and OS X environment (same device) throughout the day and I've just gotten used to the Cmd key being one key over, not too bad.
- DT Pro Member: 0167
The only thing you may have an issue with is the Alt and Windows keys could be switched to what they are usualy on windows .
You can re map that or just get used to it. I usualy just get to it as i swap between mac and windows all the time in work.
