model F 122 XT replacement parts
gorgeous_george
15 Sep 2018, 01:14
Hi all!
I recently came across an abandoned model F XT, in a forgotten basement at a university, and I promptly adopted it.
It is missing a dozen stems though, and I was wondering if those of a model M would be compatible, or if there are any differences.
My model Ms are back at home and I won't be able to check by myself for another couple of days, but I'd like to know if I have to start looking around the web for spare parts, so that I can get things going.
If you have any other advice about best practices in restoring an 122F XT, please let me know!
Thanks in advance
gg
15 Sep 2018, 01:22
An XT is one thing, and a 122-key terminal is something very different.
Key stems and caps are interchangeable, no problem.
gorgeous_george
15 Sep 2018, 01:28
I guess I must have read too much and mixed up some things.
The keyboard I found has "Part no. 1445098" and from here wiki/IBM_part_numbers it is referred to the 6110344 model (which is a F 122).
edit: if there's need for pictures, I'll be able to add them tomorrow.
edit: by the way fohat, great job on your F 122 mod post on geekhack, outstanding work!
Sangdrax
15 Sep 2018, 19:31
Orihalcon has a bunch of F parts in his sale thread in the Marketplace forum. If you mean you need keycaps, then yeah, M stuff is compatible with F barrels.
