Data General Dasher D1 review (Key Tronic vintage foam and foil)
- Elrick
- Main mouse: MX518
The SEXIEST looking keyboard that was ever made on Planet Earth
If any other manufacturer today could construct an exact copy utilizing those same key-caps on BOX Navy switches, I would be the happiest man anywhere when I lay down my money for it.
Would have to calm down considerably when it gets delivered to my address.....
- Chyros
I have to say, although it's definitely a huge looker, I like the styling on the later Dasher boards even better. Hopefully I'll be able to snag one of them at some point as well (one that doesn't cost puzzlingly and completely undeservedly much).
- zslane
- Main keyboard: RealForce RGB
- Main mouse: Basic Microsoft USB mouse
- Favorite switch: Topre
Just a point of clarification: SA Dasher/Dancer wasn't designed by 7bit, but by me.
Now even though those switches may have been a bit scratchy and stiff, they nevertheless sounded great for such old linears. And those sphericals! Oh my! *love*
- Chyros
Wait, I thought you told me you DIDN'T design them? XD
Anakey
- Main keyboard: Planck
- Main mouse: Cyborg Rat 7
- Favorite switch: Alps skcm white
seems most of the keyboards made in the late 70s/early 80s was built the same, my Rafi board i posted in the photos section had the same thick metal top plate and thick plastic casing and as a bonus it has the Rafi switches so it is able to be used and converted very nicely once the matrix was plotted out.
- Elrick
- Main mouse: MX518
- Chyros
- Sangdrax
- Main keyboard: Harris 1978 Terminal
- Main mouse: Mammoth
Not Dashers, but like my Pr1me, my Univacs, all the secondary color insets are just different colored plastic that clips in the main top case frame. Only one that was metal was the Genrad I used to own, and it was a painted metal inset plate in a full metal case. I never realized when looking at these before that the top plate was metal.
I'm mostly surprised by the combination. I figured it was always all plastic or all metal. Or if you had a combo, that the bottom pan would be what was metal. It's kind of a bizarro world feeling. Everything is upside down.
Damn pretty though. If I owned one, I'd have it cleaned, greased, refoamed and converted in double quick-time just to mess around with it. The only real concern is nothing next to the spacebar to use for Ctrl and Alt. That would drive me nuts. I don't think they fix that even by the D3.
