Tai Hao Alps modifiers
JollySkeletor
29 Oct 2018, 23:03
Hey folks - i'm in the process of assembling a quefrency board https://keeb.io/products/quefrency-60-6 ... 4552880222 using some alps switches (which the PCB supports). However, i've hit a snag in terms of stabilised keycaps.
I've got a pack of tai hao alps doubleshots - but the pcb and plate only support cherry style stabilisers, and the stabilised keys (with the exception of the space bar) have alps mount without the insert (i.e. just the two hollow squares either side of the main slider mount). Does anyone have any experience getting around this kind of thing? Thanks.
abrahamstechnology
29 Oct 2018, 23:08
JollySkeletor wrote: Hey folks - i'm in the process of assembling a quefrency board https://keeb.io/products/quefrency-60-6 ... 4552880222 using some alps switches (which the PCB supports). However, i've hit a snag in terms of stabilised keycaps.
Does the plate work with Costar stabilizers? If so, you can use Costar clips on the plate and Matias hooks and wires.
JollySkeletor
29 Oct 2018, 23:24
Don't think costars will fit.
abrahamstechnology
29 Oct 2018, 23:32
I am not sure.
flowerlandfilms
30 Oct 2018, 05:45
i know it's not very fancy, but in a pinch you can just stick some springs over the support mounts.
swampangel
30 Oct 2018, 14:22
flowerlandfilms wrote: i know it's not very fancy, but in a pinch you can just stick some springs over the support mounts.
Good to know!
It seems like you could 3d print a cherry compatible insert for the caps, but everything I found with google was going the other way: https://www.tinkercad.com/things/eM6pKpCBmn9#/
JollySkeletor
30 Oct 2018, 23:33
When you say "support mounts", what do you mean exactly? Do you mean the spaces for inserts on the inside of caps or do you mean where cherry style inserts are for the pcb mount stabs? Cheers
abrahamstechnology
31 Oct 2018, 03:11
I just tried Costar clips in a plate made for Cherry stabs, it works, but a bit loosely. Maybe some electrical tape can fix that?
JollySkeletor
01 Nov 2018, 18:25
Managed to wedge a costar clip where the cherry stab should be in the plate - fits reasonably snugly so I don't have to stick tape anywhere. Have to use alps wires though, (they're a bit thin for the costar clips as well - but they just stay in). Bit of hack but looks to be working. inb4 it explodes under actual use.
Laser
emacs -nw
25 Jan 2019, 12:53
Hei, any updates? I bought a Quefrency 65% kit and I also have some damped Alps switches, *and* Costar stabilizers, *and* Alps stabilizer wires (and keycaps and stuff from some old Alps keyboard parts). From my tests, the Costar stabs fit (I had to cut off their rear "lip"), but I will have to either bend the stabilizer wire "away" from the Alps switch, or file the Alps switch to avoid friction with the wire. Do you have some pics of your (hopefully, still) working setup? Thanks!
orihalcon
25 Jan 2019, 19:26
I haven't really ever built a custom ALPS board, but where does one reliably source Costar stabilizers from?
Laser
emacs -nw
25 Jan 2019, 19:46
I have some from an old keyboard (Cherry MX); they seems to be available in some places, e.g. (without the wires, which are not useful for Alps anyway): https://www.kustompcs.co.uk/peripherals ... abilizers/
also:
https://www.aliexpress.com/item/Costar- ... 22283.html
or:
https://www.switchtop.com/product/costa ... ap-inserts
