I've already checked this page:
wiki/SMK_second_generation
I'm designing a PCB and backplate for a keyboard that will be using SMK switches. The variety I have is the second generation, tactile Alps mount variant. I already know that the square hole on the backplate is 14mm square. What I need are the precise measurements for the two leads on the switch, so that I can create a part in my PCB software. A datasheet would have given me all this information. Thank you!
SMK second generation switch - looking for datasheet
You’re making a PCB for Montereys? Good on you. They’re fantastic.
Best of luck sourcing the info. Nothing an existing keyboard’s PCB and some callipers could do?
- DT Pro Member: 0011
LFKeyboards are sharing their PCB footprints, including footprints for SMK here:
https://github.com/lfkeyboards/public/t ... ard.pretty
They have used these for PCBs for sale, including for SMK in 65%, "78%" and TKL, so I suppose they have been tested.
