Replacement keys for special symbols on Logitech G710+
charball
16 Nov 2018, 03:11
Hi.
My keyboard is Logitech G710+
Please see attached pictures. I understand this is a gaming keyboad but it's worth investing in since it's been perfect for me other than the keys I want to replace.
The inversion of the keys drives me crazy, for example:
5 % key -> 5 is at the top.
{ [ key -> Why did they reverse that one...? I don't get it.
Anyway as you can see, besides the filth, these keys:
1. Don't light up properly
2. Have a tiny font size - Can't read important symbols when I need them
3. Non-standard character order. top symbol-> bottom symbol is reversed.
At this point I could care less about the crappy backlight on this thing. It does however feel great.
Do you guys know where to at the very least get these developer-critical specials sorted out?
(9 )0 _- += {[ }] |\ :; "' <, >. ?/
Thanks for reading
elecplus
16 Nov 2018, 03:59
Since these are MX switches, wouldn't a set of WOB caps work for you? They would not be translucent, but at least they are crisp and clear. These are the caps on my keyboard.
mcmaxmcmc
16 Nov 2018, 08:19
Bottom row might be a slight problem though, but you can work most of it out, yeah.
Lanrefni
16 Nov 2018, 08:56
Oddly enough Corsair has a set of keycaps that appear to match the bottom row-
https://www.amazon.com/CORSAIR-Double-S ... ycaps&th=1
charball
16 Nov 2018, 13:19
Woo yeah. You guys put me on the trail. I'll see what I can get!
Thanks a lot
abrahamstechnology
16 Nov 2018, 13:44
Tai-Hao has tons of options, including backlit caps.
abrahamstechnology
16 Nov 2018, 13:46
mcmaxmcmc wrote: Bottom row might be a slight problem though, but you can work most of it out, yeah.
You could use some of the 1u relegendables for the bottom row.
