I couldn't find real data about 1392373.
aside from the fact that it is french/canadian ISO, It has strange connection cable .
and what about its protocol ?
IBM Model M 1392373 ?
xxhellfirexx
https://picclick.com/Rare-Vintage-New-O ... 81449.html
It is a first gen keyboard for the short lived IBM RT workstation. Don't bother converting it.
orihalcon
- DT Pro Member: 0190
If you were to want to convert it, just throw a regular model M controller into it and protocol problem is solved, or can use one of the newer replacement controllers that say phosphorglow was making.
- DT Pro Member: 0167
Some rubber dome Ms can be good for this , they used exactly the same controller as the real M version as the both use the same membrane!
Just take your shitty run of the mill dome M , unplug the controller and plug it into the normal M .. done!
