What happens if I don't connect this back when I reassemble it? Is there a danger of electric shock? Will the keyboard work properly?
What happens if I modify the keyboard to use USB (something like this:
USB doesn't have earthing right?
I wouldn't do that. There's chassis aground and there's signal ground. If it goes to the bottom plate that is probably chassis ground. So it should go from the USB/PS2 chassis (if even connected) to the bottom plate. Signal ground is probably already connected.Myoth wrote: 25 Jan 2019, 08:52 The ground is never necessary(though there are some boards where you need it Model F for exemple), but it's usually a precaution, there is a GND pin on the pro micro, you could wire it to the one already existing if you're really scared about it![]()
I have a generic laptop charger that isn't grounded properly (2-wire) and it makes my Alps64 go crazy when it's plugged in.
Even if you did , you cannot guarantee that the outlet will be grounded, not with the 1800s electrical system you use over in the coloniesabrahamstechnology wrote: 30 Jan 2019, 17:07I have a generic laptop charger that isn't grounded properly (2-wire) and it makes my Alps64 go crazy when it's plugged in.
Also it gives a small shock when you touch a port. I ought to get a proper 3-wire charger eventually.
I was going to but the end result didn't go as expected since I've cut a new case for it manually and it has many flaws as I used just simple tools to do it.abrahamstechnology wrote: 30 Jan 2019, 17:04 What I always do for my AT101W USB mods is solder the ground wire from the plate to the USB port's shielding.
By the way, can you do a post on your AT101W? It's looking pretty interesting!
