Unknown Brand Keyboard on Ebay
twhelgeson
06 Feb 2019, 19:05
I found this eBay auction with a keyboard with an unknown brand.
https://www.ebay.com/itm/Vintage-Unknow ... Sw7wFcWPjo
Any ideas on what this could be? Worth a bid?
Anakey
06 Feb 2019, 20:03
looks like a foam and foil xt clone
imdatperson
06 Feb 2019, 22:44
When I first saw it I got linear space invader vibes, but looking closer at it I am 99% positive it is foam and foil, probably linear. I can tell due to the very distinct font.
[ XMIT ]
06 Feb 2019, 22:45
The font, the lock LEDs, and the metal backplate all suggest foam and foil.
imdatperson
06 Feb 2019, 22:48
XMIT wrote: 06 Feb 2019, 22:45 The font, the lock LEDs, and the metal backplate all suggest foam and foil.
Yep! The only way I could tell is the keycap font. I know the early XT space invader boards had a near identical case and backplate, but the font is definitely the giveaway here.
06 Feb 2019, 22:57
Guys ...
1. Use the IDENTIFY THE KEYBOARD thread!
2. Use the Wiki!
Key Tronic Model F clone series. Key Tronic foam and foil confirmed.
[ XMIT ]
07 Feb 2019, 04:25
I really need to spend more time updating the Wiki.
