did this project on a whim. wasn't sure it would work to be honest but it yielded good enough results. need to get used to the split shift but it's much easier than getting used to the odd 1.25 and 1u keys where the enter should be
Imgur album: https://imgur.com/a/b1iTppe
if you really want it to work right next to the colon, you need to flip the keycap and use the switch next to the colon as the mount point and the plate hole for the 1.25u key as the stabilizer unit
currently, the 1.25u key is inactive due to there being no contacts under the stabilizer mounting hole. gonna wire it to where the 1.25u goes to the contacts to where the original 1.25u enter was.
Feel free to comment any questions. super new to this site by the way
