I'm looking to make my first custom board, but I'm afraid I'll miss something and find myself with incompatible parts.
I'd like to put together this combo:
Case: GMMK
Switches: Purple Zealios V2 62g
Keycaps: Kalih Low Profile Keycaps
Will this combo work?
- TheInverseKey
- Main mouse: M570
- DT Pro Member: 0216
The case and the switches are fine but the switches are the wrong mount. The Kalih caps don't use the MX mount like the switches do.
- abrahamstechnology
- DT Pro Member: 0212
If you want low profile black keycaps try these:
https://www.aliexpress.com/item/dsa-pbt ... 27837.html
- anthonymak
- Main keyboard: IBM Model F101
- Main mouse: Microsoft arc
I bought this 15 bucks for two 104keys sets.abrahamstechnology wrote: 10 Mar 2019, 01:00 If you want low profile black keycaps try these:
- xTek
- Main keyboard: Redragon K551 & Dell Quietkey RT7D5JTW
- Main mouse: Logitech B100
I see. I will take a look at other sets. Thanks.TheInverseKey wrote: 09 Mar 2019, 17:27 The case and the switches are fine but the switches are the wrong mount. The Kalih caps don't use the MX mount like the switches do.
- xTek
Oh my god. They are perfect. Thank you.abrahamstechnology wrote: 10 Mar 2019, 01:00 If you want low profile black keycaps try these:
- xTek
Would these work too?abrahamstechnology wrote: 10 Mar 2019, 01:00 If you want low profile black keycaps try these:
