Future Computers/Cortron ITW Magnetic Valve Keyboard
This is a pretty rare keyboard from what I gather. It is in great condition for its age. I cannot test it because it doesn't use a standard protocol but someone out there could possibly convert it.
Alphameric 142-2762
It's a foam & foil board which I never bothered trying to convert.
DigiPos (Tipro) POS with Cherry MX blacks and relegendable keycaps
Apple Extended Keyboard M0115 (Orange Alps)
The keyboard is fairly yellowed and has not been cleaned but the switches feel good and the keycaps aren't filthy. The top right appears to have been engraved. Keyboard has been tested and is working.
Apple Extended Keyboard II with White Damped Alps, Linearised, USB modded
The broken ADB port has been swapped to the other side and a Teensy 2.0 has been installed inside with a fixed USB cable. The switches have been linearised. The plate still has signs of rust, but has been cleaned to the best of my ability.
Walters branded LCD-286/Unitech K959 Keyboard with Vintage MX Blues
I bought this with the intention of using it as I wanted to try vintage cherry MX Blues but it really isn't my cup of tea. The keycaps appear to be Pad Printed ABS (can't confirm though likely). The PCB is dated 1988.
IBM Model F XT
Restored (painted plate, foam replaced etc)
Apple Extended Keyboard II (white damped Alps)
The keyboard is in its original packaging (box and plastic). The keyboard is quite clean and not that yellowed. The plate has some rust spots on but nothing major.
Apple Desktop Bus Mouse II M2706
This mouse was included with the keyboard - I assume it was included with it. It is in fairly good condition apart from some dirt on the shell and a missing slider on the bottom.
Tipro programmable keyboard with MX blacks x2
- 20190626_130716.jpg (2.74 MiB) Viewed 7191 times
- Top.jpg (2.43 MiB) Viewed 9912 times
- 20190514_165551.jpg (1.68 MiB) Viewed 8062 times
- top.jpg (2.21 MiB) Viewed 8454 times
- top.jpg (2.05 MiB) Viewed 8690 times
- switch.jpg (1.11 MiB) Viewed 8690 times
- top.jpg (2.3 MiB) Viewed 9607 times
- sticker.jpg (1.14 MiB) Viewed 9607 times
- in box.jpg (2.08 MiB) Viewed 9620 times
- top.jpg (1.83 MiB) Viewed 9620 times
