Order Custom Cherry MX-Mounted Keycaps
zanneth
31 Mar 2019, 03:51
Hello keyboard fans.
I'm looking for a way to order a large amount of custom keycaps (approximately 213 keys) for a keyboard that I am building using Cherry MX switches.
I would like the standard ANSI set plus a couple dozen other keys with my own labels.
I don't need terribly fancy graphics but I would like high-quality printed keycaps with a color/typeface of my choosing.
Where is the best place to order something like this?
Thanks!
Anakey
31 Mar 2019, 11:46
the only place i know that would do custom printed keycaps would be WASD though the quality is questionable from what gets reported.
31 Mar 2019, 13:56
zanneth wrote: 31 Mar 2019, 03:51 Hello keyboard fans.
Thanks!
I recently had this dyesubbed set custom made by https://www.etsy.com/shop/DecentKeyboards for one of my national layout projects, and I'm pretty happy with the results.
Custom dye-subbing on Model M keycaps.
31 Mar 2019, 14:13
Anakey wrote: 31 Mar 2019, 11:46 the only place i know that would do custom printed keycaps would be WASD though the quality is questionable from what gets reported.
Max Keyboard does individual keycaps. They do colour, and backlight keys.
