Kailh Box Red Switch In Hansung TFG ART Hot Swapping Mechanical Keyboard, the Kailh BOX Switch with three fix pin,customized switch of Hansung.
http://www.monsterlabs.co.kr/src/catego ... l?pn=27744
Kailh Box Switch Hot Swapping Mechanical Keyboard
- kailh01
- Main keyboard: Hexgears
- Main mouse: lenovo
- Favorite switch: kailh switch
- kailh box switch keyboard.jpg (2.44 MiB) Viewed 9940 times
- 4.jpg (2.16 MiB) Viewed 9940 times
- 3.jpg (2.74 MiB) Viewed 9940 times
- DT Pro Member: 0011
It looks as if the USB port juts out an inch above the desk and pointing at an angle upwards.
I'm afraid that would put unnecessary strain on the socket and cable, compared to having it on a separate board (or panel mount).
Running the page through Google Translate achieves nothing — because all the information is in text rendered in images.
- kailh01
Yes,it's USB port design,it's designed by Korean Company
- abrahamstechnology
- DT Pro Member: 0212
BOX switches with fixing pins? Nice!
