I only have some photos for now but I'll be taking a shot at converting it.
Gotta go grocery shopping now but I'll also be posting a disassembly video soon.
Not with that membrane. But the membrane is in two parts (rows and columns) and a middle spacer-membrane.
I suspected as much, based on a little bit of research I did on the train looking for similar mods to Model Ms. I figured the M is such a common board that if no one's done it on that then it's not been done at all.Findecanor wrote: ↑16 May 2019, 21:16Not with that membrane. But the membrane is in two parts (rows and columns) and a middle spacer-membrane.
You could perhaps construct a custom circuit board (or membrane) that replaces the bottom membrane, on which each pad leads to a diode for that switch.
If not a custom printed board then maybe traces made with some kind of metal tape.
Did you blow it up by plugging it into your logic analyzer?snacksthecat wrote: ↑17 May 2019, 02:14Oh no, I'm getting that horrible feeling I get when I start to realize I did something dumb.
I'll give someone a little prize if they can guess what it was.
Hint: what I did is mentioned somewhere in this thread
Ding ding ding!PlacaFromHell wrote: ↑17 May 2019, 03:10I guess you put the middle membrane that separates the rows and the columns under the other two membranes, that causes all the keys to be electrically pressed. Membranes are not double-sided so you don't need to isolate them from the backplate.
You might even say, "Hell yes!"
