Beamspring Factory process - How to
- SneakyRobb
- THINK
- Main keyboard: KB-5161A, F122, Dc2014, Typeheaven, Beamspring FXT
- Main mouse: MX518 Legendary
- DT Pro Member: 0242
Hi,
I am making a thread to document my construction of new beamspring keyboards/components. I will collect designs, files and processes here. I wish to be able to make all the components of beamspring keyboards because why not. Thus I will do this.
I have worked with wcass and DMA bouncing ideas off of them as well as them helping in many ways. Obviously they have both been a big help and I couldn't have gotten this far without them.
Main imgur collection here. I find imgur difficult to use. So duplicates etc will occur.
https://imgur.com/gallery/x0B4aZV
https://imgur.com/a/mrZbist
So far I have managed to produce a cherry mx conversion for my 3278 into a 60% Ansi Keyboard.
(I have DSA "ice" keycaps now to replace the space and modifiers I borrowed from a quckfire. I know they look bad)0
Most keys do not actually need the stabilizers as beamsprings almost never bind. I have been adjusting the 3d printed stems in order to get the stabilizers to work well. https://imgur.com/bBQUrR5 https://imgur.com/aCJ01Hi
Costar stabilizer bent bars hit the return spring and are not the best.
PCB/Metal cut gerbers
These are my first pcbs. As such they do not follow any particular good design rules for pcbs. They should 'work' but they aren't elegant, or really well thought out. I can't guarantee they will work, so if you order one from a pcb maker I suggest you double check it. Obviously I have uploaded them so you can change them etc. I have opted so far to use 2 layer PCBs because they are easier to make. They use the DMA commonsense controller on an external board because it is easier to test with an external controller. These are works in progress.
From what Ive found and learned from wcass.
https://imgur.com/Yy11gH3
https://imgur.com/IwOjOw8
This style of PCB is possibly the "first" beamspring style pcb. It has many vias which were expensive to produce. The sensing pads are both on the front of the pcb, the "rows" as they were travel using vias and connected to a trace on the back. There is also a massive amount of grounding copper rows on the back.
I theorize that the "front and back" style of PCBs that are seen in later Beamspring and then Model F keyboards are a cost saving measure. As such I opted to produce a PCB which is more akin to the original and hopefully has very strong signalling.
I made an MPCNC machine to make new metal plates. I have only cut some balsa wood ones so far as I just made the machine. I will eventually attempt to use aluminium.
For the plates I have found that having a very thin 3d printed card with the "tabs" to align the keys, makes it easier to machine the plate as you need no tabs on the plate.
ansi board - 60% board
Uses mostly original keys except for space modifiers etc using cherry mx stems for those.
https://imgur.com/uVy1nQq
https://imgur.com/eh1pliL
https://imgur.com/XhMJYPZ
https://imgur.com/gWW6Otx
https://imgur.com/PCRSdSG
Model M style
I haven't actually ordered this made yet but will be doing so soon.
https://imgur.com/M79FRCu
https://imgur.com/V1yFxuf
https://imgur.com/Zst6hOx
https://imgur.com/rW9FZSH
Conversions so far have been straight forward. As you need a plate and a pcb along with the DMA controller. You can then use original switches/caps etc.
I wish to be able to DIY/DIWHY produce all components of beamsprings so I can fill out my Model M variant.
For the production of new components I am less developed.
Return Spring
Currently I am working to perfect a 3-piece 3d printed plastic stick screw. I have music wire of 0.025 inch thickness.
I have been able to wrap the wire around the stick to make new return springs. This is somewhat time consuming but it works.
The stick has 3 lengthwise pieces. The 2 outer ones have the screw guide and the middle one doesn't. I will upload this file soon.
What you do is wrap the wire around and then remove the middle stick to remove the other pieces, and there you go new return spring.
Here is a basic idea of the mechanism. It is a guide to get the winding right, and then it disassembles.
https://imgur.com/a/gWKzwPS
I will update on the progress of these springs this weekend.
*This system didn't work at all. I have been able to make some decent springs by using a makeshift brake out of 2 metal plates, a bolt/nut and wood with music wire. Must continue developing.
Foot
For the switch plate foot, black carbon 3d printed plastic seems to work somewhat. It is obviously capacitive. It doesn't matter what you make the barrel assembly out of.
I will be uploading some OBJ/STL files later tonight. The main consideration for this part is whether or not it should have a stem on it. The reason this is a question is that the original flyplate was press fit onto the foot with a metal backward fork preventing removal. I would rather use a small screw as if I am going to make flyplates, I would rather just punch out one hole in the middle with maybe 2 position post circles.
The stem can be seen in this gallery which will upload fully soon.
https://imgur.com/gallery/Jx1lnxF
Flyplate
This piece will have to be stamped somehow. I believe the easiest way would be to order a circuluar disc puncher. As the metal is 0.035 inches thick. I would then bend it on a fixture that is 3d printed.
I have been in contact with this etsy seller of custom punches. They have quoted me between 150-350 usd. I am attempting to make one of these out of aluminium currently. Even if the aluminium punch only lasts a few punches, I think it would still be cheaper to keep remaking these.
https://www.etsy.com/ca/listing/6248648 ... rket&frs=1
Beamspring - Reasonable Reproduction Achieved
For the beamspring itself, the steel is 0.015 inches thick spring steel and you can cut it with scissors. (Don't ask me how I know this.)
The beamspring itself "should" be reasonably easy to make.......... with a press as it is just a shape with a hole in the middle. Just like the flyplate, I am currently trying to source/perfect my punch press in order to make larger quantities of new springs.
Barrel Assembly
I will upload an obj/stl of this a bit later. It is a pretty straight-forward geometric object that can be 3d printed.
Keycaps
I have done a lot of research about the beamspring keycaps. They are cool. I believe that were you to try to make a production beamspring board today, the largest single expense would be the keycaps and it would quite likely take up a massive majority of the cost. As such I am not attempting to do this at this time aside from experiments.
Basic work in progress 3d models for plastic parts.
https://www.thingiverse.com/thing:3641754
I will continue to update this post in the future with files etc. Let me know if you have any questions or input.
Model M style
Return Spring
Foot
Flyplate
Barrel Assembly
Keycaps
- Full size board wip.zip
- (133.86 KiB) Downloaded 969 times
- uVy1nQq.jpg (209.28 KiB) Viewed 40637 times
- Monster-Toys
- Main keyboard: IBM Model F PC AT QWERTZ
- Favorite switch: IBM Beam Spring
Very cool project! (thx for making this thread
"The beamspring itself is reasonably easy to make with a press as it is just a shape with a hole in the middle. I am currently trying to perfect my punch press in order to make larger quantities of new springs."
Especially this sounds great.
(count me in for the first ordering round^^).
Did you think of converting to something else then capacitive sensing? I try to figure out ways to convert my switches to "normal" switches. CS is (at least in my beamspring) quite a diva and disassamble the beamspring every other day and clean it to avoid severel "hickups" is annoying.
I have several ideas for it but did not try them yet (the easiest beeing to tape a thin selfmade foam and foil pad to the flyplate. It requires another plate between switches and pcb, tho).
Doing it with custom housings could be more "elegant" (conductive plate on top of the flyplate and contacts where the flyplate rests when the switch is pressed (the two cylinders in the original) + two legs for through hole soldering).
But maybe i am just crazy.
- SneakyRobb
- THINK
Hi thanks. Again I must credit heavily wcass and DMA as well as red for his videos. Shoulders of giants.Monster-Toys wrote: 16 May 2019, 18:23 Very cool project! (thx for making this thread)
Especially this sounds great.(count me in for the first ordering round^^).
But maybe i am just crazy.![]()
I believe in other projects as well as the DMA commonsense thread people have looked into other sensing methods, pad and foot sizes and the such. You can have some variation I believe, but I am not sure. I am just working in the physical rearranging of the keys/pcb as well as production of switch pieces. There are a bunch of threads that I have seen that I have used as reference. So my board wasn't developed in a vacuum by a longshot.
There is the fext project for converting the model m to use model f components as well.
I don't see why you couldn't make a foil and foam system. It would require the work though. I have not had a problem with the CS system itself. I had my 3278 setup with no dust shield for well over 2 years with no malfunction both with both xwhatsit and dma. So I would strongly suggest trying to figure out why your system is having the issues that it is.
There is definitely room for elegance here. Wcass designed a cool case for the "HHKB" variant he designed.
My sandwhich design was more to just get a working system up and running using the commonsense. It is quite... rough.
- DMA
- Main keyboard: T420
- Main mouse: Trackpoint
- Favorite switch: beamspring
- DT Pro Member: NaN
Sorry for hijacking the thread, SneakyRobb.
What are your thresholds? Must be about quarter to halfway between "not pressed" and "pressed" levels.
-- check/fix thresholds before going below --
Do you have connection to the metal parts of the keyboard to the ground?
If you do - please PM me photos of the kit and all wires between it and the keyboard visible.
What are your symptoms? Keys not registering, repeats, something else?Monster-Toys wrote: 16 May 2019, 18:23 CS is (at least in my beamspring) quite a diva and disassamble the beamspring every other day and clean it to avoid severel "hickups" is annoying.
- SneakyRobb
- THINK
Hi, No worries.DMA wrote: 19 May 2019, 23:05 Sorry for hijacking the thread, SneakyRobb.
Very half baked update.
I will make this process easier in the near future. This is my tinkering update.
Spring progress. This is for the return springs. Not the beamsprings.
https://imgur.com/gallery/fMzgf8r
So I spent today trying to make return springs. I had some success.. but will need more work.
I had a concept of a 3d printed piece of plastic and it basically didn't work Which is good.
For this you need to use music wire. And a long 1/2 inch hex bolt. A piece of wood and some other hardware.
0.025inch thick music wire. You can use any brand/source>
Example https://www.amazon.com/PRECISION-METALS ... way&sr=8-5
A piece of wood to attach everything to.
This is basically what I modeled my process after.
https://www.youtube.com/watch?v=lhQBz6q ... e=youtu.be
I managed to make some smaller springs and will be able to soon make full size springs. I forgot to get a 1/2 nut so made some smaller ones. Most of them were average/poor. I showed the best one.
Basically. you need a piece of wood as a base. You will use 2 wingnuts on bolts to hold 2 plates of metal together. You sandwhich the music wire between the pieces of metal to compress it and not allow it to back up. It lets you keep up the tension.
You thread the wire through the nut and screw it down on the bolt. You then rotate the bolt and the wire takes on the spring shape. Then when done cut the wire and unthread it.
As you can see in the images I managed to make a smaller spring. It has decent spring characteristics and the newer 1/2 inch ones will function perfectly fine.
- SneakyRobb
- THINK
Return springs part 2.
Alright so I think this would be easier with a lathe. I do not have a lathe. So for now I will attempt to make them at home. The 1/2inch bolt I used made springs that were too big. I have read in the machinists handbook that I will need to use a smaller diameter screw in order to make springs of 1/2 inch size.
Rolling spring wire onto a 1/2 inch bolt will make a spring that is closer to 3/4 inch across.
I will also have to shave down some of the bolt in order to thread them on with the 3 and 4 bands that start the original screws.
This can be seen in this photo album.
https://imgur.com/gallery/NXQMfXR
I hope to be able to make useable springs in the next 1-3 weeks. The setup is still quite rough but I am making some progress as you can see.
- SneakyRobb
- THINK
Reorganized the original post and added some files.
- SneakyRobb
- THINK
John Doe wrote: 16 May 2019, 16:34 Splendid job. Hope to see more process going on.
By the way, if there are extra original beam spring caps to sell, PM me.![]()
Thanks for your words. I am a bit covetous of my keycaps.. perhaps in the future any other element of the board I could provide you or provide the knowledge to be constructed. !!
- Monster-Toys
I am stil not sure if i will try that on my own (but i am very tempted and startet to do 3D models and prints for housing already anyway und beeing trained in CAD ... it is tempting^^).SneakyRobb wrote: 16 May 2019, 16:24 Foot
My idea for the flyplate was to 3D print it (as i do not want to go capacitive i will use normal PLA) with 2 stems, put the flyplate spring on them and melt them down a bit (pressing a piece of hot flat metal onto it) to get sthe spring stuck. That should be simple and effective.
One can make quite good 3d printed keycaps (0.2mm nozzle and quite some postprocessing - so this would not be suitable for mass production because both, printing and postprocessing will take a long time but for a hobby project ...). I am not sure if 0.2mm nozzle would be fine enough for nice legends but i would imagine with some fiddling and a dual extruder printer (i do not own one but that might be a good reason to get one) it might be doable.SneakyRobb wrote: 16 May 2019, 16:24 Keycaps
edit: with my single extruder printer i would print legends as indentation and fill them up later. Am working on a test keycap at the moment.
- SneakyRobb
- THINK
That flyplate design is interesting. I had considered a similar sort of method where I would print a hole into it, and use a 3dprint pen to shot the last bit of plastic in it to seal it, a rivet of plastic melted could also work. I mostly again just want to avoid having to stamp out the complicated shape in the middle of the flyplate.
I have 3d models for all pieces I shared above, they don't work that well and I am in the process of tweaking them.
In terms of keycaps I think you could probably print quite good keycaps, especially with one of those (resin?) style printers. I only have a .2mm nozzle right now. For those legends I if you are thinking of filling them In I wonder if printing the keycap minus legends and then maybe using the 3dpen might work as well. Perhaps you could laquer them first. The cavity doesnt necessarily need to be filled with PLA, it could be filled with another sort of material, sanded to be smooth and then sealed in.
As well I wonder if the sort of resin custom cap process could work. Like those "klacks/brobots etc" it seems entirely possible to make a new beamspring cap.
Regardless I am not quite at the stage of keycap production or have it on the radar, especially with easily printed cherry mx stems I designed and the existence of custom community made keycaps. I have also seen other forum members print their own cherry mx stems.
- Monster-Toys
I printed a blank test keycap with my FDM* printer (0.2 mm nozzle). It took around 3 hours. WIth some post processing the key is very smooth and shiny and it fits perfectly on the beamspring switch. Funny what you said about the 3d pen, i had the same idea^^ (i do not own one tho).
Printing MX switch mounts seems to be more reasonable.
I came up with some ideas and prototypes how to make a switch with as little time and money investment as possible and had some ideas for a low profile beamspring switch made ... i just need to get 0.015 inches thick spring steel to start making a prototype. Should i make my own thread or just keep posting here, too? (my own thread might be less messy)
* resin printers bring very nice results but the resin is quite expensiv, they are extremly messy and the fumes are quite toxic
- SneakyRobb
- THINK
Hi,Monster-Toys wrote: 23 May 2019, 18:32 I printed a blank test keycap with my FDM* printer (0.2 mm nozzle). It took around 3 hours. WIth some post processing the key is very smooth and shiny and it fits perfectly on the beamspring switch. Funny what you said about the 3d pen, i had the same idea^^ (i do not own one tho).
It would be up to you. You seem to have a different sort of switch method in mind. Lower profile, sensing method and the such. I think a different thread might be a good idea. I am not that organized and you might find it easier to keep your files and everything in order. I think you have the thread that I started posting in before I made this one right?
I have also been experimenting with shortening the switch. It seems like along length of the slider portion you could remove perhaps 5mm of length and shorten the switch in this manner.
I think you could plausibly delete at least the area in the redlines here.
There is also this product which obviously has shortened the mechanism albeit with different dimensions of spring.
https://kono.store/blogs/keyboards/silo-beam
Something like the ALPS plate spring switch might also be good to investigate. It uses a somewhat similar method of clicking.
If you don't have an ALPS plate spring switch, I can mail you 1 or 2 of them.
- SneakyRobb
- THINK
Smaller update. Will make a larger update in a few days. I accidentally got 0.015" thick spring steel. The correct number should be 0.0015" thick steel. Doh.
I have been printing a lot of barrel housings, stems and capacitive feet. I have got the basic shapes pretty close to correct. Obviously the original ones were very smooth versus the layered 3d printing. So they are... scratchy.
For no reason I am also making brass beamsprings. Because why not.
I will take some close up photos of the pcb for interests sake.
For stabilizers I have been debating how to stabilize the keys. Almost every key except the spacebar doesn't seem to need a stabilizer. Even the space bar though can essentially be pressed anywhere and still register. I may just slice a channel along the front of a switch housing to fit the stabilizer.
This is the case design that wcass came up with. It uses 2, printed/milled side pieces that hold the plates from the side and uses aluminium extrusions as the front and back. I had to tap the holes to make threads which wasn't too difficult. The front will hopefully make the front a bit easier to type on. I may still design a 4-5 inch long flat wooden leadup/wrist wrest.
I will be assembling this soon to give the keyboard a more put together look.
- SneakyRobb
- THINK
Hi,
So I apparently made my side parts with incorrect measurements and it doesn't fit together properly so the case wont get together today. Sad face. I will reprint them.
Here are some versions of the side parts to keep the whole thing together. These aren't really necessary as the screws and switch housings basically themselves with just the bottom and top plate provide the necessary retaining force. The sides and front are just for aesthetics and somewhat ergonomics.
Here are some closeup pictures of the pcb for the ansi 60% one when they arrived.
The basic idea as said before is that unlike the "later" pcb which basically looks like the Model F one, this one has both capacitive pads on the front of the board. In theory this should make a stronger more consistent signal. This method uses a lot of Vias which were expensive back in the day, which is why I believe (I need to verify this) they went with the less expensive method of the second set of sensing pads on the back of the pcb for later versions. This is not actually the downgrade that it might seem like though. That method obviously didn't need as much drilling and basically itself is still super reliable anyway as seen by the various old model f pcbs that still work. I mostly did it this way for retro-fun after wcass originally showed me the old pcb.
As said, I post these to collect thoughts, have fun and share the learning. I don't have a specific time frame in mind. I will be doing some experiments this weekend with the 0.0015" thick metal that the beams themselves are made of.
- SneakyRobb
- THINK
Just a small manic video to show the extreme insanity of the horizontal stability of beamspring switches. I can press this spacebar along its entire length with no stabilizer of any kind and it will still actuate. Every press in this video clicks the spacebar.
I am just going to make a model m/f style bar stabilizer in the future. Working with the cherry mx stabilizers has not really worked easily at all and they don't seem necessary.
https://gfycat.com/achingobedientiberiannase
https://www.youtube.com/watch?v=V2bFOE2TTYw
- anthonymak
- Main keyboard: IBM Model F101
- Main mouse: Microsoft arc
excellent !
- SneakyRobb
- THINK
thanks anthonymak,
It has been a bit laborious trying to cut beamsprings by hand. The 3dprinted punch die also does not work very well. It will have to be metal. I am hopeful the acid etching process will be easier. More to come Sunday.
I have my 3dprinted carbon black feet, PLA clearish housing, screws, taps and mx sticks. The switch is kind of scratchy as it is 0.2mm PLA, but everything seems to work. I am ordering a 0.1mm nozzel to use with abs.
Right now I have new pieces except for the flyplate spring and the coil return spring.
I also made a slight error with the PCB by not putting the fake pads by the spacebar to connect to the bottom row. Dur. Must re-order that.
- SneakyRobb
- THINK
Hi,
So using scissors isnt the best. But. But. I did make a "new" beamspring. The scissor method is currently the easiest. It is a bit tricky though as the spring is 20mmx3mm.
I believe that some kind of printer toner acid etching might be much better. The first one I made was kind of suck and a bit deformed but it works.
I believe my method of marking out the lines caused the deformation. I haven't been able to make a reliable punch die yet.
Regardless. Here is my first new spring in action.
https://youtu.be/LarHD7B1cCk
- SneakyRobb
- THINK
Hi,
And here are the capactive feet. There isn't much too these. Just a 3d printed carbon black conductive filament.
- PlacaFromHell
- Main keyboard: IBM 3101
- Favorite switch: Beamspring
I notice they are not flat, but we need to make them this way? Maybe cutting squares from a sheet will work as good as these non-flat feet.
- SneakyRobb
- THINK
Hi,PlacaFromHell wrote: 09 Jun 2019, 22:46 I notice they are not flat, but we need to make them this way? Maybe cutting squares from a sheet will work as good as these non-flat feet.
I modelled the feet after the original feet and their geometry. If you see here when I press down the switch, the fly spring bends downward to follow the angle.
It might be possible to make them from some other material, but it took me 8 minutes to make 4 feet. I have enough of my $30 roll of capacitive filament to make almost 2 model m layouts worth of beamspring capacitive feet.
- PlacaFromHell
I understand now, that's cool. I'm so hyped with this project!
- SneakyRobb
- THINK
Hi, thanks. I think We can really make it happen.PlacaFromHell wrote: 09 Jun 2019, 23:48 I understand now, that's cool. I'm so hyped with this project!
- SneakyRobb
- THINK
Hi, so I spent a while trying to use scissors to cut new beamsprings in a bit of a more nice fashion.
I have now marked this component as DONE. My basic conclusion from this process of making new "beamspring" components works. It can be a bit finicky and annoying but it works. I have now made multiple beamsprings. There is an unreasonably large amount of room here for refinement I would note.
I use m2x3mm screws to attach the springs to my sliders. The 2mm screw shaft fits through the 1.5mm hole punch I use.
My caliper showed the original beamspring at 0.001" inches thick. When I used this type of spring steel, and I did order legitimate cold rolled spring steel, it seemed thinner and very prone to bending and specifically creasing. Metal of 0.0015 and 0.002 thickness worked better. Luckily I got an assortment package from online retailer with multiple thicknesses.
You will need:
A metal hole punch of diameter 1.5mm. I go this one on the online retailer but you can use any you find as long as it can cut metal. Try to support local businesses when possible. This is not an affiliate link. https://www.amazon.ca/gp/product/B01L1J ... DWE6GHQVV9
This sort of item is generally used to make jewelry with large copper sheet pieces.
A sheet of spring steel, likely 0.002" inches thick.
A pair of decent scissors, you need those scissors that when you use them are like heavenly as they slide together. Basically ones that cost like $20.
A sharpie or other very thin tip marker that can leave ink on steel.
A clear ruler with mm indicators.
Drawing
Use the marker to mark out a point called center.
Mark this point and hole punch it. You will then draw a rectangle centered on this
of dimensions 20mm x 3mm.
Cut that shape out with your scissors.
It may be wider or slightly longer than the original so try to trim it.
Now at either end, you will cut, 1mm down from the tip a slit of about 0.8mm toward the center. It is a bit hard to see.
Then from the end cut down to those previous cuts to make a interior corner. You will do this 4 times. You basically want a tab at either end of the spring that can fit into the flyspring part.
The result is a 20mm long x 3mm wide piece of metal of either 0.0015" thick or 0.002" thick spring steel with a 1.5mm centered hole. It will have 2x 1mm tabs at either end.
Various attempts shown here of various levels of success.
The main rectangle portion then is 18mm long and the 2x 1mm tabs bring it to 20mm full length.
That's it. You have made a beamspring with scissors.
You will need to cast or 3d print a slider with a 2mm hole capable of accepting a 2mm screw. For my sliders I have added 2 small guides to make the spring not able to rotate. This is not pictured here. Without tabs, there is nothing preventing the spring from freely rotating aside from screw friction.
You will need:
Drawing
- PlacaFromHell
Maybe you could mark, or even cut the parts using the same process as with the old fashioned handmade PCB's. Toner printing or something similar over the sheet you want to cut and then give it a bath in a hot acid or salt like ferric chloride. Maybe the second part is inviable because of the sheet thickness, but at least you can print the footprint of the cuts and sublimate it over the sheet before go with the scissors.
- SneakyRobb
- THINK
Hi,
Quick update but I took manisteinn's idea about the flyspring plate and ordered a test batch.
I will be trying to bend these into the right shape and will report back later how well they work!
- beamspring stencil flyspring.jpg (1.39 MiB) Viewed 39000 times
- SneakyRobb
- THINK
Hi,SneakyRobb wrote: 29 Jun 2019, 18:20 Hi,
So the flysprings that I got basically work but they do need some adjustment. They are almost tactile right now. Sort of having more of a bump. I think this is because the curve that I put on them is more of a folded line.
The originals were bent into shape but have a nice curve to the top, mine have a sharper bend.
I may get some jewelry pliers in order to bend them to a more correct shape.
Regardless they do work. I used 4 mil stainless steel which is a bit thicker 0.004" vs 0.0035" than the original.
Original.
The new ones dont hold on as well. The screw variant works alright.
Side by side
- SneakyRobb
- THINK
Hi, I have thought of using this sort of process but I want to avoid using it. While I think it may work better for mass production, for my purposes I might just spend 4 hours cutting out like 20 new beamsprings by hand.PlacaFromHell wrote: 17 Jun 2019, 03:08 Maybe you could mark, or even cut the parts using the same process as with the old fashioned handmade PCB's. Toner printing or something similar over the sheet you want to cut and then give it a bath in a hot acid or salt like ferric chloride. Maybe the second part is inviable because of the sheet thickness, but at least you can print the footprint of the cuts and sublimate it over the sheet before go with the scissors.
- SneakyRobb
- THINK
Hi,
So after many attempts at bending the flysprings I am refining a 3d printed molding block. So far the best way to get the gentle curve has been to use jewelry looping pliers. I think the 3d printed form will be easier in the long run and at home when I need to make over 100 for the full size beamspring keyboard.
Here we can see the corners being too sharp when I tried to bend with regular pliers. Bad idea.
Here I am using the looping pliers to make the curve into a nicer shape, still a bit hard to align it and make it square. The corners though have that nice curve which is what we want.
The curve is about a 2mm diameter rod so I used the 2mm part of the pliers. It works pretty well, but getting it to be perfectly aligned is hard.
I am trying to perfect a bending tool that uses the center peg to align it all so it can be easily bent by hand. I think this will be the easiest method. it is just a small piece of plastic that is slightly tighter than the original shape so it springs.
I have about 100 extra flysprings coming in the mail next week and id rather use the tool than the pliers.
