IBM ISO Enter stabiliser peg - which way does it go?
Wazrach
23 Aug 2019, 21:40
Just got a lovely Unicomp set for my 4980 Model F. Not sure which way the stabiliser peg goes for the ISO Enter. Anyone got pictures? Thanks!
Fkazim
23 Aug 2019, 21:46
There is only one way it can go as one way the key will be extremely stiff and the other way will be nice and smooth.
Hope that helps.
Wazrach
23 Aug 2019, 21:47
Fkazim wrote: 23 Aug 2019, 21:46 There is only one way it can go as one way the key will be extremely stiff and the other way will be nice and smooth.
Hope that helps.
That's what I mean - it will be extremely difficult to remove once it's in there.
Wazrach
23 Aug 2019, 21:48
Hope that helps.
You able to take off the Enter keycap on one of your ISO Ms and have a look for me? I'd really appreciate it. Thanks.
Fkazim
23 Aug 2019, 21:50
Ok will do that now for you.
Fkazim
23 Aug 2019, 21:53
As requested the image of how the stabiliser goes.
Hope that helps.
Wazrach
23 Aug 2019, 21:55
Thank you! I did put it in that way, but the Enter key is a bit rattly. Hmm.
Wazrach
23 Aug 2019, 21:58
Yeah there's no way that's in properly. It binds if you hit it at the bottom.
Wazrach
23 Aug 2019, 22:29
Problem solved. Just needed to be reseated. Thanks Fkazim!
Fkazim
23 Aug 2019, 22:37
No problem glad I could help. :D
