[Bought] Two 3u space bars + stabilizers
zrrion
09 Oct 2019, 02:55
Looking to get two 3u MX mount space bars as well as the required stabilizers. I'd prefer white, yellow, or black if you have it, but honestly I'll take what I can get for the time being.
I have what I was looking for, thanks to kbdfr for the lead
09 Oct 2019, 04:08
I’ve got at least a white one, from Round 5. Don’t know anything about stabs, though.
zrrion
09 Oct 2019, 04:11
If it comes down to it I can get the tool for bending stab wires, the caps are the biggest hurdle.
09 Oct 2019, 08:26
3u space bars fitting Cherry switches are common on Access-IS POS keyboards:
https://www.ebay.co.uk/itm/132705666261
https://www.ebay.co.uk/itm/174052497850
https://www.ebay.co.uk/itm/173878922949
https://www.ebay.co.uk/itm/192489373253
I probably have a white one, but am unable to look for it at the moment.
kokokoy
09 Oct 2019, 09:46
Got my 3u stab from faxe before. Not sure if he still has some though.
zrrion
10 Oct 2019, 05:32
kbdfr wrote: 09 Oct 2019, 08:26...
this was a very good lead. I have ordered 2 POS boards that have 3u spacebars so I should have what I need cap wise, but these being POS boards I am not sure if they have stabs or if they just use multiple switches. I'll update once I find out since I'll either have mu stuff, or I will need stab wires still.
10 Oct 2019, 07:50
zrrion wrote: 10 Oct 2019, 05:32
A pic I took years ago:
zrrion
10 Oct 2019, 19:44
Dang, yours looks clean. Thank you for the pics.
EDIT: Stuff came in, I have caps and stabilizers now, no longer looking for caps
Return to “Want to buy”
