The most useless keyboard in existence?
Fkazim
09 Dec 2019, 14:37
I was browsing for keyboards today and found this. The layout is beyond useless I just had to share this find. I can't even begin to think how difficult this would be to use on a daily.
09 Dec 2019, 14:49
That is most likely a general-purpose keyboard which has been specialised for some special purpose in an embedded computer. It must have been cheaper than manufacturing a specialised keyboard from scratch.
You see similar keyboards now and then.
Fkazim
09 Dec 2019, 15:00
Yes I see what you mean. A lot of wasted space though the keyboard could have been a lot smaller judging from the key layout.
swampangel
09 Dec 2019, 15:45
I wonder if you took the cover off, if the board would have keyswitches in the other positions (just no caps) or if it would be totally unpopulated
Fkazim
09 Dec 2019, 16:56
swampangel wrote: 09 Dec 2019, 15:45 I wonder if you took the cover off, if the board would have keyswitches in the other positions (just no caps) or if it would be totally unpopulated
My guess is it would probably be unpopulated just to save money.
User101
09 Dec 2019, 22:20
Its of some medical system if I recall correctly. Let me try to find some pictures
User101
09 Dec 2019, 22:27
Here
DDD
10 Dec 2019, 05:28
yea, 101 and 87 layout is the best. I just want to know which switch variant inside the keycaps.
Fkazim
11 Dec 2019, 04:23
DDD wrote: 10 Dec 2019, 05:28 yea, 101 and 87 layout is the best. I just want to know which switch variant inside the keycaps.
Possibly Cherry MX Blacks.
Ilostmytoeinvietnam
13 Dec 2019, 16:41
At least they have an iso layout lmao. I wish we would go back to this time when thick durable plastic cases were normal, and the sound is allowed to run rampant. That case is just bonkers for what the keyboard actually is.
