So I did a foam replacement today and everything went well, I got everything closed up and all the keys are working fine during normal use. I have noticed though that on the up stroke the keys vibrate quite a bit as the spring decompresses. I am not sure if that was there before.
The issue is that when I pull any key cap off, the computer reads the key as always being pressed. I've tried it on multiple keys across the board and the same thing happens. The second I put the key-cap back on it stops and works like normal. Does this indicate a problem with the keyboard? If so, any ideas on what to do to fix it? Do I need to perhaps use thicker foam or something? (Currently used 1.5mm Neoprene and had a hard time getting it closed up even with the help of clamps).
Any help/info would be much appreciated!
