[IC]thick Cherry PBT caps DE
mintberryminuscrunch
31 Mar 2012, 09:52
Hi,
Is anyone interested in thick cherry PBT caps? And how much do you want to pay for them.
Mbc
Tarkoon
31 Mar 2012, 09:57
What is so special about that?
All original Cherry PBT caps are thick... (as far as i know =)
31 Mar 2012, 10:14
Tarkoon wrote:What is so special about that?
no, only the older ones
Tarkoon
31 Mar 2012, 10:27
Ok, then I always had older ones. =) Thanks!
31 Mar 2012, 10:29
Tarkoon wrote:Ok, then I always had older ones. =) Thanks!
Btw. The larger ones (shift, enter) are always thick
gimpster
31 Mar 2012, 18:09
Would this only be for DE layout? Is that what the title means? Or is there any chance of getting them for a US ANSI layout?
rindorbrot
31 Mar 2012, 18:34
mintberryminuscrunch wrote: The larger ones (shift, enter) are always thick
to confirm this: Pic of Lasered PBTs from my G80-3000 LQCDE (bought new in 2011)
BTW: what colour would they be and will they have stepped, off-center Capslock?
Spacebar PBT, too?
31 Mar 2012, 19:01
I would pay for Swedish/Finnish layout, or possibly for Danish or Norwegian. I have got two sets of thick PBT keys in German layout already ... With Danish or Norwegian, I could mix and match with those I have to get Swedish.
31 Mar 2012, 21:52
gimpster wrote:Would this only be for DE layout? Is that what the title means? Or is there any chance of getting them for a US ANSI layout?
yes only german iso
rindorbrot wrote:BTW: what colour would they be and will they have stepped, off-center Capslock?
Spacebar PBT, too?
standard cherry, so stepped caps, 1.5 mod keys,...
colour would be white (the beige one, not the greyish one, from newer keyboards)
