I helped a guy at work clean out a few of his 6 barns recently and he let me have two mechanical keyboards that I found in one of them (there were others)
I was trying to find the value of this first one but now I'm just intrigued with the keyboard and want to clean it up and try to use it. Anyways, after taking it apart I see its a Hi-Tek 725 series that is not listed on the page that is here.
Mine is a Hi-Tek 112136 according to the inner shell.
The switches are white but I have only taken off a few because I dont want to break anything and they have springs that just pop out.
The circuit board itself says:
NME Hi-Tek Corporation Series 725
A/W 112550 Rev A
294VO 8539
And if I'm reading the date code correctly its: June 5, 1986
Found a Hi-Tek 725 that's unlisted here
Hypermiler314
- Main keyboard: G513
- Main mouse: G502
- Favorite switch: Blue variants
- DSC05192.JPG (3.66 MiB) Viewed 1603 times
- DSC05190.JPG (3.16 MiB) Viewed 1603 times
- DSC05188.JPG (3.43 MiB) Viewed 1603 times
- DSC05186.JPG (2.79 MiB) Viewed 1603 times
- DSC05184.JPG (3.43 MiB) Viewed 1603 times
- DSC05183.JPG (3.48 MiB) Viewed 1603 times
- DSC05179.JPG (2.45 MiB) Viewed 1603 times
- DSC05178.JPG (3.39 MiB) Viewed 1603 times
- DSC05177.JPG (2.32 MiB) Viewed 1603 times
- DSC05174.JPG (2.8 MiB) Viewed 1603 times
- TheInverseKey
- Main mouse: M570
- DT Pro Member: 0216
Hi,
This keyboard is listed under the following location on the wiki: wiki/Hi-Tek_Series_725_second_generation
This is a second gen AT layout keyboard and they are quite common but nice find none the less.
Hypermiler314
- Main mouse: G502
I was talking about in the "Known part numbers" area.
Am I missing something, in the list
"112083, 112980, 112980"
Mine is a 112550 right? There is alot of sets of numbers I'm not sure which ones are which.
Hypermiler314
- Main mouse: G502
Here is the finished product of breaking it out down and detailing it.
- 725 Detailing.jpg (3.93 MiB) Viewed 1399 times
