Beamspring keycap’s mounting slot(oval and rectangle)
kevinhou
24 Mar 2020, 18:54
Is there any difference?
Weezer
24 Mar 2020, 19:49
The smaller (rectangle) one came later and is a cheapening of the product. They're more likely to break/crack in my own experience.
SneakyRobb
THINK
24 Mar 2020, 20:03
Hi, This may be a cheapening but I am not sure. If you notice the black keycap here has thinner cross supports, but has a heavy oval center. The white cap has the rectangle but also thicker cross supports.
Those two keycaps are from the same keyboard.
The other cap is not a beamspring cap, but a selectric cap. I think this might be the reason for the difference.
viewtopic.php?t=20345
In this thread as well you can see selectric caps/beamspring caps with inconsistent steams. I am unsure why this is, but I there were multiple factories making keycaps for the same stem that have variations.
SneakyRobb
THINK
25 Mar 2020, 02:39
Probs should have added the photo... The 2 together are from the same beamspring. The other one is selectric.
