What switch?
Fkazim
16 Apr 2020, 21:21
Hey guys would like some help identifying what switch this keyboard might have.
Thanks.
What switch.PNG (952.21 KiB) Viewed 3537 times
16 Apr 2020, 21:58
That must have been been yanked from a typewriter. I have seen similar keycaps from an AEG typewriter, and those were Cherry MX-compatible.
I think it would be easier to find info if you searched on the model name of the typewriter.
Fkazim
16 Apr 2020, 22:02
The keyboard has a ps/2 connector was there any typewriters with detachable keyboards?
Willy4876
17 Apr 2020, 05:02
I'd say it is more likely a word processor keyboard. I'm guessing that mostly from the arrow keys and some of the legends like recall phrase. That sounds like more of a computer-like function than even some of the later more advanced electric typewriters.
Willy4876
17 Apr 2020, 05:21
This is the closest looking thing that I found from a quick google search. It looks similar to what Fkazim posted but this one has a nav-cluster.
https://forums.bannister.org/ubbthreads ... 78&page=70 (Scroll down a bit)
This lead me to search for Olympia Olytext machines and I found this DT thread. I cannot say for sure that this is going to have the same switches but it would make sense.
viewtopic.php?t=18286
I hope it helps.
Willy4876
17 Apr 2020, 05:28
Sorry for the duplicate. Was trying to edit the first one.
Fkazim
17 Apr 2020, 11:14
Yeah that looks very similar to it Thanks.
19 Apr 2020, 01:22
Fkazim wrote: 16 Apr 2020, 22:02 The keyboard has a ps/2 connector was there any typewriters with detachable keyboards?
Mind that not all 6-pin mini-DIN plugs are PS/2. SGI and Commodore Amiga keyboards also used that connector, and there are yet more interfaces using mini-DIN with other number of pins.
A word processor sounds likely. Some typewriter brands did make word processors.
cheesy_jones
19 Apr 2020, 14:03
Findecanor wrote: 19 Apr 2020, 01:22 A word processor sounds likely. Some typewriter brands did make word processors.
Time was you couldn't go into a Sears without running across a million of them. They all seemed cheaply built and unreliable next to a real electric typewriter. The world has changed.
