What are your methods to fixing this?
The keyboard just arrived an hour ago and I've already broken it
I lost the piece shortly after, looks like that's it for me.Fkazim wrote: 27 Apr 2020, 13:36 I would recommend to stick with some glue. Should be an easy fix as you have the broken piece still partly attached.
I tried to tape it using double sided tape, didn't quite work as well as I thought. I can try duct tape actually.ricky miller wrote: 27 Apr 2020, 15:47 That looks bad! Try and paste it with some adhesive and see if that works, Otherwise, I don't see any fix to this.
Thanks! It looks so fun too. I'll try it for sure mate.
